Woops. Attached battery backwards. What do I check?
Old 12 Feb 2016, 03:54 pm
Default Woops. Attached battery backwards. What do I check?
So my car wasn't working, I messed with it and put the battery on backwards. (so dumb)
BUT The car worked after I reattached it right! For a whole day! I started it up at least 8 times.
Then now it doesn't work.
What could've blown in the electrical system? What should I check?
Old 12 Feb 2016, 04:58 pm
Default Re: Woops. Attached battery backwards. What do I check?
Check the systems voltage.
Check the battery by load testing it.
Check all your relays and fuses.
Check the battery leads both at the battery and also the frame/body and starter.
You may have just killed the battery.
Old 12 Feb 2016, 06:25 pm
If you didn't do anything else, it may be the original problem you had before when your car wouldn't work.
Does the starter turn and engine not "catch"?
Turn key and hear "clicks"?
Old 12 Feb 2016, 10:08 pm
_PTGT03's Avatar
it probably your main fuse. ive done it befor but on a suzuki (it happens man, don't sweat it ) . should be located in the power distribution centre just under the clutch slave resevoir
Old 12 Feb 2016, 10:40 pm
Hello. I have a 2004 PT Cruiser.
Car didn't start.
Replaced Starter. Worked great. For a week.
Then didn't start. Made one click and a little hum. All lights lit up.
Battery was fine.
Then days later. Car started! Worked great. For a week.
Then car didn't start. Same. Made one click, little hum. Didn't work for two weeks.
Checked the starter relay. Ok.
Checked the battery. Ok.
Checked fuses. Ok.
Today, hooked up battery. Didn't pay attention an d I hooked it up backwards. The negative wire fell and hit what was the positive terminal, while the positive wire was hooked up to the negative.
Hooked battery up the right way.
Car suddenly works again. But now my interior lights, and radio don't turn on.
Did you check the fuses when the interior lights and radio didn't work?
You need to post every step you do otherwise we have no idea what you have done.
Does your engine light come on? If so what are the codes?
Old 12 Feb 2016, 10:49 pm
Steve I never read his other request...geeeeezzz I don't read every thread on this forum ...
So another member doing multiple threads inquiring about the same thing?
Good luck helping this member.
Old 12 Feb 2016, 11:55 pm
I agree.
I give up on this one...
Old 13 Feb 2016, 12:01 am
I don't mind a challenge as long as I get the answers I need.
NitroPT likes this.
Old 18 Feb 2016, 05:50 pm
Sorry for the laate reply. I'll check the main fuse thanks!
I suspected the starter was bad, but I just took it out and got it bench tested. It was fine.
When you start the car, how many volts are supposed to get through to the part on the starter that connects to the ignition. I heard you need at least 9 volts to get the car started.
I'm pretty lost and defeated at this point honestly. );
Old 18 Feb 2016, 08:28 pm
I thought you replaced the starter as posted in post #5
Also bench testing the starter does not check the starter under a load. It can still be bad.
Cranked 2008 PT cruiser with battery hooked backwards Plantman Tech & Performance Forum 3 15 Feb 2014 07:04 pm
Awesome cruiser my my house! Pic attached Youngmaninanoldmanscar General PT Cruiser Discussions 10 11 Jan 2013 06:53 pm
Attached my Flame Grille Badge? Retroguy Exterior Accessories Forum 11 23 May 2011 05:54 pm
Why is my Autoloc keyless entry fob working backwards? bettyrubble76 Interior Accessories Forum 8 19 Sep 2009 12:45 pm
what are the two silver modules attached to the turbo mino General Turbo Discussions 2 23 Oct 2007 02:19 pm
