Went DEAD
Old 14 Feb 2016, 04:15 pm
Default Went DEAD
I drove about 30 miles
after that went for oil change
after oil change drove 1 miles & after the rail tracks
all lights came on & car went DEAD . No light / no response
I asked for jump & in ONE jump back to normal
What could be the issue !!
regards
Note: has 80K miles
Old 14 Feb 2016, 05:50 pm
Default Re: Went DEAD
I would suggest that when the oil was changed they loosened or pulled a wire or when you went over the tracks it triggered the PT Cruiser to go dead.
Do you have a lot of keys on your key ring? If so the weight of the keys might effected the ignition switch if the ignition switch is worn out.
If your PT Cruiser is an 2001 or 2002 you might want to check and see if you have wires hitting the axle under the engine shorting to ground.
If your battery cable connections are loose it could cause it to go dead. Check and make sure your cable connections are tight.
What year is your PT Cruiser?
Old 14 Feb 2016, 06:14 pm
2006 , 80K miles
Yes after reaching home first thing I checked was battery connectors seemed ok but I tighted up
No just two keys in keychain
May be some loose connection
Let me know if you think of something, its my wife's car so dont want her to get stuck
Old 14 Feb 2016, 11:33 pm
Originally Posted by sunny8088 View Post
2006 , 80K miles
If you have the TIPM you really need to check the battery. The PT Cruisers with the TIPM are extremely sensitive to voltage drops. I would take the caps off the battery and check the battery levels. On one of my PT Cruisers I have to check the battery every 3 months. Get the battery load tested. You can take it to Sears and they will test it for free.
Old 15 Feb 2016, 09:50 am
Personally, Sears is the LAST place I'd take a battery. I guarantee if you take it there, you're going to be told you need a new battery. Probably $150 one at least! Autozone, Advance, NAPA, Pep Boys, O'Reilly or Car Quest will all be better choices. Find the closest one to you and take it there. No disrespect, Steve, but based on personal experiences and knowing folks that have been screwed by Sears, I avoid them.
Old 15 Feb 2016, 10:17 am
Chuzz, sorry you have been having that experience. I watch the person doing the load testing and check to make sure they are doing the load testing process correctly each time I take it there. Have you been charging the battery before taking it in for load testing?
Nitro's way of checking a battery
Old 15 Feb 2016, 04:27 pm
UPDATE
My wife said she noticed Oil change light came couple of time's and chimed & went off
Just for clue.
Old 15 Feb 2016, 07:23 pm
UPDATE 2
I went to AutoZOne battery & Alternator tested OK
What we found is battery is loose in compartment and can move
Thanks
Old 16 Feb 2016, 12:41 pm
Fk5 Fk5 is offline
UPDATE 2
Thanks
I had this problem back around 2012. Car was acting crazy - dash lights flickering, all the lights coming on and going off. When I checked my battery terminals, the connections seemed fine, but the battery was moving around and causing intermittent problems and at times completely disconnecting and killing the engine. I think I actually realized what it was and fixed it at the toll booth for the GW at 3 am Christmas. Tightened it down and no problems (same old battery) since.
2003 GT 5 speed
162,000 miles
Old 16 Feb 2016, 08:40 pm
UPDATE 2
Thanks
Glad you found the problem. This will help other members in the future.
dead ecm? ecu? msj113 Tech & Performance Forum 2 04 Mar 2014 04:08 pm
Help dead pt Bigdog General PT Cruiser Discussions 3 16 Apr 2012 09:42 am
dead car klondikeone Tech & Performance Forum 4 09 Nov 2010 02:02 am
Dead PT need help benjibbad General PT Cruiser Discussions 7 26 Mar 2010 03:10 pm
Dead, again renichms General PT Cruiser Discussions 6 03 Jul 2003 10:42 pm
