Fog Lights
Old 15 Feb 2016, 04:12 pm
Default Fog Lights
Hello,
So just today, I happened to notice my fog lights will not work. The bulbs appear to be good, so I checked the fuse box and it looks like maybe a couple fuses are missing? Any help would be appreciated.
Old 15 Feb 2016, 04:38 pm
cruserdad1976's Avatar
Default Re: Fog Lights
multi function switch its n the steering coloum
Old 15 Feb 2016, 05:11 pm
What year is your PT? Up to the '05 model, there's a fuse in compartment by driver's left knee that is for the fog lights - the cover tells you which fuse is for what.
Be careful when you put the fuse in - the lights may come on by themselves and drain your battery, because of a bad switch.
Old 15 Feb 2016, 11:59 pm
bubba_1952's Avatar
There could be several reasons for no fog lights. Fuses under dash and/or under hood, multifunction switch, melted wires in steering column or a combination of all or some. Sad to say but start with the easiest first and work your way up. Most times original owner pulls fuses when multifunction switch shorts out and they don't want to replace it or don't know that was the problem.
Bubba
2004 Limited Edition Platinum Series Dark Graphite Metallic Clearcoat Turbolight A/T
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Tail lights, dash lights, a/c panel lights not working ZZCruizer Tech & Performance Forum 12 14 Dec 2015 11:11 pm
ABS, traction lights, parking break lights ON and Cruiser control doesn't work Fab Feedback and Support 0 08 Jun 2015 08:28 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
Need a poll answered: Should I tint all my lights or buy euro/projector lights? 85_305 Exterior Accessories Forum 2 17 Jun 2009 08:38 pm
