Disconnected Heater Hoses-now won't start
Like Tree3Likes
  • 3 Post By PTTexan
Old 19 Feb 2016, 01:51 pm
Default Disconnected Heater Hoses-now won't start
Hello Everyone....I'm stumped at the moment. I temp. disconnected my heater hoses due to a blown heater core (to be fixed soon). Now I get nothing from the starter - Instrument panel lights up as normal...MIL image is now shown.
Started fine several times this morn...but nothing now. I checked around the area where I've been working to see if I disconnected anything,...checked my battery - OK,...can't figure it out so far! Any suggestions?
Thanks! 2008 - 2.4 no turbo
Old 19 Feb 2016, 02:40 pm
Default Re: Disconnected Heater Hoses-now won't start
where did you disconnect the hoses? in front of the motor, along the side near the TIPM ( fuse box)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 19 Feb 2016, 02:46 pm
Thanks for your reply.....disconnected at the firewall by the fuse box. I checked the 4 multi-pin plugs that are right there - the one closest to the hoses was a little cocked because of my leaning on it a little....but I disconnected it and re-connected it so that it flushed up with the other three.
Old 19 Feb 2016, 02:48 pm
LionPT's Avatar
Pull this plug back out & look for bent or broken pins.
Old 19 Feb 2016, 03:02 pm
OK....I figured it must be something like this since I removed battery and cleaned posts/clamps to try & eliminate that possiblity...put the battery on a 40amp quick charge but its amps were already ample...I'm fairly sure it's not the battery....will go out and check that plug now. Thanks!
Edit: Checked the plug - there was a receptor/pin that was pushed down below the others - all the rec/pins were a bit loose - I'm trying to slip the "guide sleeve" (for lack of actual term) over the rec/pins in order to re-insert assembled plug into socket (checked the pins inside the "socket" receptacle and all appeared OK) - now done with no success of starting the engine
Old 19 Feb 2016, 08:07 pm
If you have a voltmeter I would check to see if you have 12 volts going to the solenoid from the ignition switch when you are trying to start the engine.
Does the security red light stay on on the dash when the ignition is on?
Old 20 Feb 2016, 08:50 am
No volt meter to check that. The only symbols that remain on are the two seat belt figures and the battery symbol. Thanks to everyone so far!
Old 23 Feb 2016, 04:01 pm
Turns out to be in the fuse box - I had found a blown fuse earlier but when replaced, it still didn't work....apparently there was a break in the circuit beneath that fuse. All's working now - thanks for each of your input!
Crankcase breather hose disconnected? roaoro General Turbo Discussions 11 07 Feb 2014 09:50 am
disconnected battery and p0888 code 02 pt cruiser donsims30 General PT Cruiser Discussions 0 24 Mar 2012 01:37 am
Heater Hoses NavyCruiser Tech & Performance Forum 3 22 May 2011 04:23 pm
What is this and why is it disconnected? bjagd02 General PT Cruiser Discussions 3 17 Jul 2010 08:35 pm
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
