Grinding noise
Like Tree2Likes
  • 1 Post By 03TXPTGT
Old 25 Feb 2016, 10:23 am
Default Grinding noise
OK so I get a grinding noise that can be felt in stearing wheel when I turn to the left but only while pressing the gas pedel.. I changes the break pads and rotors looks just fine. Anyone have any ideas?When going straight or turning left no noise...
Old 25 Feb 2016, 10:30 am
03TXPTGT's Avatar
Default Re: Grinding noise
Check the wheel for play after it is on a jack stand.
It may be a bad wheel bearing.
03TXPTGT
-2003 Chrysler PT Cruiser GT
-Patriot Blue, Bright Silver Metallic rear spoiler, billet grille, 17" chrome wheels, hyperground cable, Spectre short ram CAI
-119,000 miles and counting ...
Old 25 Feb 2016, 10:50 am
cruserdad1976's Avatar
cv joint dosent usally grind but who klnows
Old 25 Feb 2016, 01:16 pm
OK so with car jacked up there is a bunch of play in teh passanger wheel
Old 25 Feb 2016, 02:20 pm
check top to bottom wiggle and side to side
also check tyrod for wear, this will not cause grinding but needs checked for safety.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 25 Feb 2016, 02:22 pm
03TXPTGT's Avatar
Sounds like your wheel bearing is probably shot, which is fairly common.
03TXPTGT
Old 26 Feb 2016, 11:14 am
Wheel bearing likely as stated.
noise turning right check left
noise turning left check right
also check to see if you have a rock stuck behind the brake rotor.
Mike
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Grinding noise bogaz Wheels, Tires, Suspension 1 22 Jul 2012 03:20 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
