Installing center console
Like Tree2Likes
  • 2 Post By bubba_1952
Old 27 Feb 2016, 01:14 pm
BC1 BC1 is offline
Default Installing center console
Hi,
I've got a 2008 automatic PT Cruiser I am trying to put the center console back in but I can't get it over the emergency brake. Does anyone have any ideas please?
Old 27 Feb 2016, 02:10 pm
bubba_1952's Avatar
Default Re: Installing center console
Did you recline the seats all the way back? Also, pull the brake all the way back as far as you can get it. Will be even easier if you take passenger seat out.
Bubba
2004 Limited Edition Platinum Series Dark Graphite Metallic Clearcoat Turbolight A/T
Old 27 Feb 2016, 02:38 pm
BC1 BC1 is offline
Yes I've got the seats all the way back I get the console over the shifter but when I try to line up the emergency brake doesn't come up far enough to go through the hole
Old 27 Feb 2016, 05:49 pm
LionPT's Avatar
Try to pull the brake up 1 or 2 more clicks if you can.
Make sure that you plug in the front power socket first, you won't be able to see it once the console is back in. Once you get everything lined up & have the brake almost in...shift the car into neutral...push the console as far as you can towards the front of the car..it will give/bend a little...just enough for you to push it past the curved plastic at the front of the brake slot.
Old 28 Feb 2016, 06:52 pm
It's possible to lock out the automatic adjuster and get the parking brake handle to the full up position. The console slides right in then.
Here's a short video I shot on the process (sorry about the poor quality of the video, but it should give you the idea):
05 CENTER CONSOLE UPGRADE njsteve1 Members PT Project 11 19 Mar 2014 08:59 am
Center console disassembly Carl48 General PT Cruiser Discussions 12 27 Nov 2012 10:08 am
Replacing center console ndmuse Interior Accessories Forum 4 24 Aug 2011 06:00 am
Center floor console Jimbo Interior Accessories Forum 10 15 Aug 2004 11:03 pm
center console lchiwahs Interior Accessories Forum 19 02 Nov 2003 11:26 pm
