Electrical issues
Like Tree3Likes
  • 1 Post By JoeX
  • 1 Post By chuzz
  • 1 Post By ptcruisersteve
Old 27 Feb 2016, 04:25 pm
Default Electrical issues
After the blizzard of 2016 my battery died. Well I changed it about a week ago and have had issues ever since. Airbag and brake lights came on in the cluster and my brake light and turn signal lamps light up when I use the brakes. Then yesterday then right front headlamp stop working. The last time the headlamp went out, I changed it and it still didn't work, long story short I had to get it reset. Does anyone have any ideas of what is going on.
Old 27 Feb 2016, 05:24 pm
Default Re: Electrical issues
What year and mileage please? What do the battery terminals look like, are the clean?
pvjones57 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Feb 2016, 05:26 pm
Check the battery grounds on the inner fender behind the battery. Maybe they need a good cleaning and tightening.
Old 27 Feb 2016, 05:33 pm
Terminals are some what corroded but not bad I will remove and wire brush them tomorrow. I will check the ground behind the battery also. My PT is 2006 Touring model with 126000 miles
Old 27 Feb 2016, 06:10 pm
The 2006 PT Cruisers are very popular for electrical problems related to the TIPM. You might want to have the TIPM checked out.
The link below gives an example of another member having problems with the headlight on a 2006 PT Cruiser.
One Headlight Won't turn on!
Old 27 Feb 2016, 06:24 pm
Thanks for all the advise and will work on it tomorrow.
Old 27 Feb 2016, 11:57 pm
I purchased an 06 a while back and hi beam would not work , only fix was new TIPM... Car lasted a little over a year, ran great, now it will not turn over unless I jump the starter directly, no time at the present to look more and to cold outside.
Hope your is just a burned out bulb.
73 Charger SE
01 Sebring flip
Old 29 Feb 2016, 10:53 am
thecabinguy's Avatar
Default Electrical System Differences
I have a question that I just cannot seem to find a definitive answer in a forum. I have two PTs ('02 and '05). A friend has an '07. He is having electrical issues with his car. We discovered that things are different from the first generation to the second. I know that the system is different, but has anyone ever found out WHY Chrysler made this big change from '05 to '06? If the first gen seemed to be operating fine (like my two), why the change to confuse things? Is the second gen better? Anyone have any ideas? We were just really curious.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 29 Feb 2016, 12:29 pm
Default Re: Electrical System Differences
They call that "Progress". It goes on and on and on.
73 Charger SE
01 Sebring flip
Electrical Issues UGH! commosutra Tech & Performance Forum 20 06 Sep 2014 07:59 pm
having electrical issues PT_L01A General PT Cruiser Discussions 4 04 Sep 2013 10:15 pm
'01 Electrical Issues Mabel General PT Cruiser Discussions 1 15 Apr 2012 06:22 pm
Help Please ! Electrical issues. thegooch2 Tech & Performance Forum 5 16 Aug 2010 06:53 am
Electrical Issues? SillyEB Tech & Performance Forum 5 02 Jul 2009 10:52 am
