Air Box Size
Old 03 Mar 2016, 06:54 pm
Default Air Box Size
Does anyone know if the bottom portion of the air box for a 2002 PT is the same size as the one for an 03 GT? Reason I'm asking is because mine is missing the little tabs off the back side of it that the holes in the top part fit into to help lock it down. Now, I realize I'll have to modify the air horn off the side that runs to the fender,but that's easy enough. It does have the little tabs on the bottom of it that press into the rubber grommets underneath, like the one in the GT. Anyway, I grabbed it at the junkyard for ten bucks while looking for a couple of hoses for mine. Cooked and brittle on the turbo air box and split and broke. No charge for the hoses, but the air box will be returnable for yard credit if it doesn't work. I plan on making it work.
Old 03 Mar 2016, 07:01 pm
03TXPTGT's Avatar
Default Re: Air Box Size
Total airbox on a 03 GT is different.
If you need one, PM me.
03TXPTGT
-2003 Chrysler PT Cruiser GT
-Patriot Blue, Bright Silver Metallic rear spoiler, billet grille, 17" chrome wheels, hyperground cable, Spectre short ram CAI
-119,000 miles and counting ...
Old 04 Mar 2016, 07:52 am
I'll let you know, man. I'm going to check to see if I can make this one work first. Thanks.
Old 04 Mar 2016, 08:26 am
03TXPTGT's Avatar
If it works, post some pictures. I'd love to see it.
Good luck brother !
03TXPTGT
Old 04 Mar 2016, 08:57 am
if your air box has any damage, i would be very careful how you proceed. if what happened to me happens to you, you might not have a turbo anymore.
here's a new one
rim size bkh67 Wheels, Tires, Suspension 2 05 Aug 2010 05:33 am
RIM SIZE Kalel8 Wheels, Tires, Suspension 2 28 Jun 2008 06:13 pm
Cat size KingKole02 Tech & Performance Forum 4 21 Mar 2006 01:54 pm
what size for 18'' steve smith Turbo Wheels/Suspension/Handling 2 23 Dec 2005 04:24 pm
Rim size Ronni DK Wheels, Tires, Suspension 1 17 Dec 2005 11:31 pm
