Starting problem?help
Old 04 Mar 2016, 08:22 pm
Default Starting problem?help
The symptom is like this:
When I turned the key, I only heard a 'click', and starter did not engage.
However, if I did not release the key, I hold the position of the key, after about 0.5 sec, the motor started.
What is the possible issue? starter, relay, ignition?
Thanks.
Old 04 Mar 2016, 08:51 pm
Default Re: Starting problem?help
I would suggest doing a battery load test with the battery in the PT Cruiser.
If that is okay I would check the voltage coming from the ignition switch to the starter solenoid. Post the voltage you are getting.
Old 05 Mar 2016, 09:30 am
One thing to try. Hit the starter with a wooded handle from a hammer or something. If it starts right up you need a starter.
starting problem skinnyp Tech & Performance Forum 10 09 Apr 2016 04:46 pm
06 starting problem rhythmbone Tech & Performance Forum 8 23 Jul 2013 05:54 am
My Starting Problem biker49 General PT Cruiser Discussions 2 18 Mar 2013 10:14 am
01 PT Problem with starting car Vengence General PT Cruiser Discussions 1 04 Apr 2009 01:29 pm
starting up problem packrat007 Tech & Performance Forum 11 15 Aug 2008 04:38 am
