2003 turbo coolant
Like Tree6Likes
Old 06 Mar 2016, 05:58 pm
Default 2003 turbo coolant
I just bought my 2003 5speed turbo dream and just noticed the coolant reservoir is freaking empty, I can't even tell what kind of coolant my engine is running because it needs that special coolant and I don't want to add the wrong kind. The car was parked an hour ago is it safe yet to open the radiator coolant cap? Or would it still be under too much pressure? What type of coolant is that special coolant and Where can I buy it? HOAT coolant right? Would o reillys it Wal-Mart have it?
First I need to determine what type is in side already, what color it is.
Old 06 Mar 2016, 06:12 pm
Default Re: 2003 turbo coolant
O Riley Auto parts store has an universal coolant that is supposed to be compatible with the Chrysler hoat coolant that i believe is in it currently. The reservoir is empty so i can not determine the color of the coolant until i open the radiator cap but I'm waiting for the motor to chill off more. But from the looks of it the coolant reservoir appears a little reddish orange in ccolor from the residue.
Old 06 Mar 2016, 06:38 pm
Umm I opened my radiator cap and it looks like just clear water wtf? Is that bad? The residue around the edges are pinkish. What do i do until i can do a radiator flush, which can be up to 2 weeks from now when i get paid. Is a radiator flush something i can do myself in my driveway with minimal ratchet tools and wrenches and a car Jack? Can i just add water to my reservoir tank or compatible coolant from my local auto part store?
Old 06 Mar 2016, 07:34 pm
I would first suggest you fill up the coolant reservoir to the proper level with water and see if you start loosing water after driving it.
If you are loosing water from the coolant reservoir there is no point in putting HOAT coolant in the coolant system until you find the leak. If you can't find any water leaking then its time to have an coolant compression check done.
How many miles on the PT Cruiser? Did the previous owner indicate that the engine has it been overheated?
Old 06 Mar 2016, 08:20 pm
84k miles, i think i saw clear coolant but it must've been hoat cuz i just picked up g05 hoat coolant and it was pretty much clear too. There's no coolant leaks. Carfax indicated dealer services done around 50k and 70k.
Old 06 Mar 2016, 08:47 pm
So the previous owner purposely left no coolant in the coolant reservoir? There has to be a reason for no coolant in the coolant reservoir. I would suggest keep an eye on it.
Old 06 Mar 2016, 09:30 pm
LionPT's Avatar
Antifreeze Chart
Click pic for full size
Old 07 Mar 2016, 08:30 am
Fk5 Fk5 is offline
If in doubt, I would have just put distilled water in it and drained it a few times to flush it. Then gone with the G05. The only reason I would have avoided that would have been if you might see freezing temps. I ran mine on nothing but distilled water for a couple of months in the summer while I worked out some leaking/weeping issues and my temp was always perfect. Of course now I am running through a new batch. These radiators are lame.
2003 GT 5 speed
162,000 miles
Old 07 Mar 2016, 09:13 am
I recommended to always fill the reservoir with water only during problem evaluations.
A pressure test on the cooling system is needed.
thecabinguy and LionPT like this.
Old 07 Mar 2016, 11:13 am
if your in an area that is in freezing temps right now I wiould use a unaversal coolant instead of water. Other wise water would be the way to go. You have a leak somewhere. Need to fix that before worrying about the kind of coolant. Listen to these guys and the will help you find the problems.
turbo coolant roncole24 General Turbo Discussions 3 15 Jan 2015 08:44 am
2003 gt turbo coolant lines DODGETHIS General Turbo Discussions 0 24 Jan 2013 09:08 pm
Coolant Overflow Tank Turbo/Non-Turbo? DriftWoody General Turbo Discussions 5 06 Aug 2012 10:43 am
2003 - Smells Like Coolant, Just Started Overheating AllisonInVirginia Tech & Performance Forum 5 08 Dec 2011 05:24 pm
2003 GT Turbo - coolant fan spins too fast dutchwhigham General Turbo Discussions 4 13 Sep 2010 03:59 pm
