Crank no start situation
Old 07 Mar 2016, 08:15 pm
Default Crank no start situation
Hi all. 2001 Pt touring 5spd with 109k on the odo. Went out to go to work the other day and it wouldn't start.. Figured I'm out of gas so I put 2 gallons in. Visually checked fuel pressure at valve and seemed week so I checked fuse was good so I replaced the pump. Now the pressure is visually greater than before. I am:
-Getting fuel
- Getting spark(so crank sensor is ok)
-Cam is turning upon pulling can sensor(so timings belt is ok)
-relays and fuses are all good
What in the world can it be? Autozone suggested a compression test but it ran like a champ earlier that morning so it shouldn't be internal like that.. I'm stumped. Any and all help is much appreciated guys and gals
-Devin
Old 08 Mar 2016, 01:23 am
Default Re: Crank no start situation
-Getting fuel
-Devin
Is the engine service light on?
Did you try getting the codes from the car?
Try to start it with the cam sensor disconnected?
Are you going to wait until the belt breaks to replace it?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 08 Mar 2016, 08:58 am
Try a little starting fluid in the throttle body and see if it hits.
Old 08 Mar 2016, 05:26 pm
I was only getting a 1684 code.. tried disconnecting the cam sensor and it started and died and when it died the rpm gauge jumped up like a thousand or two thousand rpm.. Replaced cam sensor with new one and still nothing.. How do I check the magnet pickup for the cam sensor?
Old 08 Mar 2016, 10:45 pm
I would suggest you check the wire harness coming from the crankshaft sensor. The 2001 & 2002 are popular for the wire harness to drop down on the half shaft or frame and start rubbing through the wire harness shorting out wires.
crank no start conrad PT Cruiser Videos 8 20 Sep 2016 02:34 pm
Crank no start on 02 PT Cbdani2 Tech & Performance Forum 10 26 Aug 2014 03:31 pm
CRANK BUT NO START clifford General PT Cruiser Discussions 3 27 May 2014 11:15 pm
crank no start 69charger Tech & Performance Forum 13 18 Sep 2013 07:04 am
