Dipped headlight indicator won't switch off 02 crd
Like Tree3Likes
  • 2 Post By LionPT
  • 1 Post By Whathaveistarted
Old 09 Mar 2016, 11:11 am
Default Dipped headlight indicator won't switch off 02 crd
I'm new to the whole cruiser thing.got an 02 crd 2.2(I understand this is just a UK/eu model)but my understanding is the interiors are the same. Anyway having sorted a solution for my ignition and having it running now(albeit very shaky on idle) I've noticed the dipped headlight indicator light stays on no matter what.
Putting indicator stalk on either left or right turns it off,as does pushing down with a little pressure but obviously when releasing it it comes back on.
I've had a look round the board and have seen there's an issue with fogs,doing the same,but this is dipped headlights I'm assuming same issue Internally.. Can it be repair with out buying a new stalk.
Cheers.
Old 09 Mar 2016, 11:18 am
Default Re: Dipped headlight indicator won't switch off 02 crd
Cheers.
That's the signal for fogs here. The go off when on high beam. Do you might be fighting the same issue. In the tech section how to's. There are some switch repaire threads. Or just get a new one.
Old 09 Mar 2016, 11:50 am
LionPT's Avatar
UK PT's use fuse #22 in the PDC under the hood. If you pull that, your fog lights won't work & light will go out. You can leave it like this or replace the switch to get fogs working again.
Front Fog Light Fuse
Old 09 Mar 2016, 01:37 pm
I figured as much after looking it up.had no idea where the fuse was so that helps. I'll have a crack at the repair thanks for the link, I'll also keep my eyes peeled for a new unit.thanks for the help guys.ill be glad when I can actually drive the bugger.
Thank you both
Old 10 Mar 2016, 09:43 am
Did it today all sorted now thank you again everyone
Old 10 Mar 2016, 09:46 am
What did you do? Replace the switch?
Old 10 Mar 2016, 11:59 am
No I stripped it down and clean the contacts and reinforced the switch which had worn away as per the link further up and it worked spot on
Fk5 likes this.
Old 10 Mar 2016, 05:18 pm
Glad to hear you fixed it yourself and saved some money.
FS: 2008 OEM 'Combo Switch' (turn signal/headlight switch) Maxxam Classifieds: For Sale/Trade 3 08 Aug 2017 06:23 am
The headlight ON interior indicator light not working Blonde62 Turbo Wheels/Suspension/Handling 4 27 Apr 2015 04:08 pm
Indicator/Wiper/Headlight not working arorag Tech & Performance Forum 5 31 Jan 2013 02:55 pm
Bad Headlight Switch ksrcrider Tech & Performance Forum 2 16 Jan 2012 06:29 pm
Headlight switch info havensole Tech & Performance Forum 4 24 May 2011 05:30 pm
