Wont crank! Please Help!!!
Old 11 Mar 2016, 02:59 pm
Unhappy Wont crank! Please Help!!!
I just had my motor mounting bracket and front mount replaced. The motor had to be removed to do the work. Upon putting everything back together it wont crank. Any ideas?
Old 11 Mar 2016, 03:51 pm
Default Re: Wont crank! Please Help!!!
I forgot to add...it has 140k miles. Once put together it ran a cam sensor code. Replaced it and it wont crank.
Old 12 Mar 2016, 07:09 am
It won't crank or it won't start? Does the engine spin and not start or just not spin at all? Be specific.
Old 12 Mar 2016, 11:26 am
How long did it take to do the repair?
I would make sure the battery is fully charged.
If the battery and battery cables are okay then check and see if you sketched some wires when moving the engine up to replace motor mounts.
Old 12 Mar 2016, 12:31 pm
rckstein's Avatar
Did you do the work or a shop? When was the timing belt replaced?
This is why I'm such an advocate of replacing the center motor mount when the timing belt work is done. Easy to do then and only a few dollars for the part and labor.
Old 12 Mar 2016, 03:17 pm
Sorry for the delayed response. The work is being done at a shop. The car was registering a cam sensor code. They replaced the sensor and nothing. Come to find out they accidently broke my timing belt. Thank you for your responses they are much appreciated.
Old 12 Mar 2016, 03:35 pm
LionPT's Avatar
How did they manage to do that..?? Replacing the mounts has nothing to do with the timing belt.
They "accidently" broke the timing belt? How the hell did they manage that? The cam sensor is on the drivers side of the car. All you have to do to get to it is remove the air box and filter. Two 10mm bolts and a plug to disconnect. This makes no sense to me at all. I'd be contacting an attorney.
Old 12 Mar 2016, 03:44 pm
rckstein's Avatar
I certainly hope they will be fixing that at no charge?
Several other members have had problems with the center mount, and some don't believe that the engine has to be removed to replace it, even though that is what the service manual states. If you don't mind revealing it, regardless of the current problems, and being optimistic that the shop will fix it and get it running, but what was their initial estimate to remove the engine to replace the center mount? I'm just curious what a job like that costs, because a dealership replaced the center mount on my PT, but did it by removing all the components just as if they were doing a timing belt replacement, but still cost $1500.
Old 13 Mar 2016, 12:37 pm
lol!!!
Sorry to hear bud....
But ya they royally screwed up and will be paying for it with a ton of labor... again.
--2006 pt cruiser non turbo owner. Completely stock... For now.
2010 PT Wont Crank BluesTex Tech & Performance Forum 13 24 Aug 2015 09:38 pm
no crank clffkirts Tech & Performance Forum 1 03 Jun 2015 08:46 pm
Installed New Radio, Interior Lights wont wont, Radio Doesnt receive "Constant" Power Mc5Cent Interior Accessories Forum 0 08 May 2013 06:12 pm
2007 PT cruiser died, parts replaced, engine codes are gone, but car wont even crank andrewsmith1984 Tech & Performance Forum 9 30 Dec 2012 10:44 pm
wont crank please help destinbeachbum Tech & Performance Forum 9 01 Dec 2012 04:34 pm
