DTC and ABS codes
Old 11 Mar 2016, 03:55 pm
Default DTC and ABS codes
Hello,
2003 PT Cruiser GT turbo, 95000 miles
Does anyone have a complete DTC and ABS code list?
The link in the sticky is broken.
My 2003 PT GT started acting up last week and I received the following codes:
PO551
PO700
PO841
ABS 04
The ABS code has turned off ABS and TRAC.
Old 11 Mar 2016, 04:04 pm
Fk5 Fk5 is offline
Default Re: DTC and ABS codes
Originally Posted by oreos View Post
Hello,
PO551
PO700
PO841
ABS 04
You can google them, but I'm pretty sure that 551 is something with the power steering pressure sensor. I never had it (knock wood) but my cousin did on his Jeep. The 700 is a generic auto transmission problem code. Not sure about the others.
2003 GT 5 speed
162,000 miles
Old 11 Mar 2016, 04:23 pm
I purchased the Innova 3030F scanner and I retrieved the codes but without a book it's a PITA to find the ABS codes. I just called Innova and was told that ABS code 04 is the Front Passenger Side wheel sensor.
This morning I changed engine oil and topped up the power steering and transmission fluids. I cleared the codes and drove the car for an hour..... haven't seen any warnings....but I still want to know why I got the codes.
Transmission: I was really surprised to find the oil was down almost 2 quarts ! Luckily, transmission shifts smoothly and didn't have any slippage...Replaced oil with ATF 4 but will replace with new MOPAR ATF4 oil/filter and gasket next week. Last change was at dealer when the vehicle had 40000 miles
Power steering: no strange sounds or visible leaks. Fluid was slightly below Cold level.
Engine: Changed oil/filter with Castro High Mileage motor oil. Found some oil around Oil Pressure Switch...will replace switch next week.
Old 11 Mar 2016, 04:31 pm
Just found this post from skylight (re-post from thegoldpt)
Don't see code PO841 or ABS codes but most other codes appear to be listed.
Error Code List
038 and 032 codes??? Car won't run windsblow Tech & Performance Forum 5 24 Aug 2014 01:11 pm
codes genet General PT Cruiser Discussions 7 08 May 2013 04:12 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
