Sticky Horn.
Like Tree2Likes
Old 11 Mar 2016, 04:07 pm
Default Sticky Horn.
Our 2009 PT has a sticky horn, which is quite problematic. It sticks about 90% of the times that it is depressed, and I have to keep pounding on it to get it to stop. Sometimes, that can take a good bit of time. What can be done to defeat this very annoying problem?
God Bless,
Nathan
(2009 PT/ non turbo/auto)
Old 12 Mar 2016, 07:11 am
Default Re: Sticky Horn.
Take the passenger side fender liner loose and unplug the connectors to the horns. Or try to find which fuse controls them and remove it. That would be easier.
Old 12 Mar 2016, 07:33 am
LionPT's Avatar
Part # 52029417AB | eBay
Old 13 Mar 2016, 12:53 pm
dougs's Avatar
This is a common problem with the 06 - 10 models. The center cover is too tight over the airbag mechanism. There was some sort of Service Bulletin issued by Chrysler associated with the problem. We have this problem with our 06 (not as bad as yours, apparently) in that to work the horn you must really bang the upper left corner of the center disc. Otherwise it won't work. We were supposed to take it in to the dealership to have it fixed, but we havent yet. Call Chrysler customer service; tell them that you have had this problem since day one, and what is the SB number, so you can take it to the dealer and have it fixed at no charge...
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Old 13 Mar 2016, 01:08 pm
rckstein's Avatar
The horn ring part has been replaced twice on my PT, once under the regular warranty, and again under my extended warranty. The problem reoccurs every once in a while. I'll have to check into the SB. I'll have to look at my receipts for the part number that they installed. Since mine has been replaced twice, it should be the current part they used.
dougs likes this.
Old 14 Mar 2016, 12:40 am
Many thanks, to all who responded. Sorry that it took the time that it did, for me to reply back, but there had been a replay of internet problems.
I do, truly, appreciate the responses, and really hope that I can get this matter in hand, before much longer. I don't really want to disable the horn, altogether, as there can be times when a sounding horn is very much needed.
But, what is this 'SB' number, that has been mentioned in this thread?
God Bless,
Nathan
Old 14 Mar 2016, 04:31 am
rckstein's Avatar
I found this:
COMMUNICATIONS:HORN ASSEMBLY
TSB: 1900106
NHTSA ID#: 10019524
Date Announced: 02/14/06
Summary: Horn Activation Effort
I can't find an actual copy of the TSB as everytime I find a link, of course it takes you to a website where they want you to purchase a subscription to TSB's.
Old 14 Mar 2016, 04:55 pm
valiant1966's Avatar
"SB"=Service bulletin. Official notices of known problems by the manufacturer. They actually admit that they have a problem.
2001 Limited Edition(non turbo)-Auto
Old 21 Mar 2016, 09:42 pm
rckstein's Avatar
The first time they fixed the horn issue on my PT, they installed:
MOPAR 68002385AA
The second time they installed:
MOPAR 52029416AB
Old 14 Apr 2016, 09:01 pm
Hadn't been doing much driving at all, in the PT. I really don't like traveling about without a properly working horn. I DID get the chance to speak with someone at Chrysler, and inquired about any service bulletins, or recalls (if different) on this issue. After checking into it, the technician replied that there were no such bulletins - or anything else - ever having been brought about, regarding a sticking horn.
Yesterday, I happened across a fellow member's posting which referenced the same problem. I learned that the culprit could one of two things: either a sticking horn, or a faulty steering wheel. The former would be at a cost of about $200, with the steering wheel at a cost exceeding $1000. A sticky horn WAS fixed, but the repair didn't prove to be permanent. The OP had to look at taking his PT back to the shop, to make the same repair, AGAIN.
Wow.
God Bless,
Nathan
Is There A How To Sticky For This? NewPTCruiserInPA Tech & Performance Forum 10 23 Mar 2012 12:04 am
Sticky Caliper? Dovebringer Wheels, Tires, Suspension 2 21 Nov 2010 08:27 pm
Another Sticky quicksilverdon Tech & Performance Forum 3 29 Nov 2006 02:39 pm
