What is leaking???
  • 1 Post By wb2kki
Old 13 Mar 2016, 02:50 pm
Exclamation What is leaking???
Hey everyone. I have a leak in my PT and I can't figure out what it is. The fluid is brownish not black. Looks like a gasket issue but i can't identify what the component is. Picture below. If you are orientated as if driving, the leaky part is between the front wheels, a bit left off center. Any and all help would be appreciated.
Very recent work to the car has been an oil change and engine mount replacement. Not sure if that could be helpful.
Old 13 Mar 2016, 03:04 pm
Default Re: What is leaking???
the picture is of the gear cover on the transaxle. That would seem to be trans fluid. If your oil isn't black. It could be a oil leak from the engine on that end. Or your trans fluid is dirty and that's leaking. Find the highest point that is wet. That should give you a location of the leak.
Old 13 Mar 2016, 03:34 pm
Thank you so much!!! Would you say the car is safe to drive? Not forever just to go to the garage?
Old 14 Mar 2016, 06:45 am
No telling how long it's been leaking and you've been driving it like that anyway, right? So, yeah, drive it to the garage.
Old 14 Mar 2016, 09:43 am
Pick up a dye kit comes with dye uv light and glasses.
Start with most likely place add dye and look for leaks.
Brown oil sounds like very old trans fluid so start there maybe.
If it is trans fluid the leak may be least of your problem.
Mike
LionPT likes this.
Old 14 Mar 2016, 09:47 am
LionPT's Avatar
Mike
Tracer Products Dye-Lite TP3090-0601 - Gasoline Engine Oil Dye | O'Reilly Auto Parts
Tags
leak
BOV already leaking! WPTF General Turbo Discussions 3 10 Mar 2014 03:55 pm
Oil leaking Subwaymike General PT Cruiser Discussions 4 16 Feb 2014 10:52 pm
Leaking oil cap? CreepyPT Tech & Performance Forum 3 29 Oct 2009 12:16 am
Oil Leaking kairobsor Tech & Performance Forum 4 30 Aug 2009 01:10 am
oil leaking ptma767 General PT Cruiser Discussions 11 20 Feb 2008 07:42 pm
