New head gasket, now crank and new start...
Like Tree6Likes
  • 3 Post By LionPT
  • 3 Post By PTDriver231
Old 14 Mar 2016, 07:25 pm
Default New head gasket, now crank and new start...
First post....I have found some good advice on this site in the past, so I thought I would join.
The PT was running before teardown. After a low compression test on 3 and 4 and exhaust in the coolant, it was time for a new head gasket. The head gasket was installed after having the head resurfaced. Reinstalled everything according to the manual and now it is cranking but won't start. Getting new codes PO129 - low barometric pressure, PO340 - Cam sensor, PO335 - Crank sensor and PO122 - Throttle Position Sensor. Timing was double checked and it is spot on. Pulled the spark plug from cylinder 1 and there is no spark...
I'm just looking for some advice on where to go from here. Could these 4 new codes be related to the same issue? I am planning on inspecting all the wires for these sensors tomorrow.
Any help is greatly appreciated!!!!
Thanks
Old 14 Mar 2016, 07:28 pm
LionPT's Avatar
Default Re: New head gasket, now crank and new start...
The Cam Sensor & Ignition Coil plugs are the same...some users in the past have switched them by mistake...try swapping them.
Fk5, Handy_Cruiser and Gkon like this.
Old 14 Mar 2016, 10:22 pm
Wow.. thanks for the quick response. I couldn't resist going back to the garage tonight and yes...it started right up. Thank you again you saved me a headache or two
Old 15 Mar 2016, 09:29 am
Handy_Cruiser's Avatar
LionPT is the MAN!
Old 15 Mar 2016, 09:37 am
cruserdad1976's Avatar
way to go isn't it odd they are the same plug?????
Won't start after timing belt and head gasket replaced blackSCpt Tech & Performance Forum 32 13 Sep 2015 11:11 pm
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
head gasket replacement and cam/crank relearn jhnhardee PT Cruiser Convertible Forum 0 18 May 2011 09:02 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
