Left hood up in rain! NOOOOOOOooooo D:
Like Tree9Likes
  • 2 Post By Handy_Cruiser
  • 2 Post By NitroPT
  • 3 Post By LionPT
  • 1 Post By FrostDrive
  • 1 Post By Fk5
Old 15 Mar 2016, 06:11 pm
Unhappy Left hood up in rain! NOOOOOOOooooo D:
I have a PT Cruiser, and I had NO IDEA I didn't know what I was thinking. ):
But I left the hood up one night, and it rained really heavily all night.
The next day it died on me, and I had to push the gas pedal a lot just to go 20mph and the car wouldn't go much faster than that.
When I put it in reverse now I HAVE to push gas just to make it move. And it just drives odd now.
What should I check since everything got wet? Google isn't very helpful.
Thanks everyone! I wanna drive my PT );
Old 15 Mar 2016, 06:16 pm
Handy_Cruiser's Avatar
Default Re: Left hood up in rain! NOOOOOOOooooo D:
Check to see if the spark plug wells are full of water.
The way the valve cover is made, it might trap rain water under very heavy flow even though it appears to be designed not to. And if the spark plug wire boots are not on good or are worn out, the water can get into the wells. This may partial ground out the spark if the boots don't seal on the plugs as they should.
buddyiramae and Gkon like this.
Old 15 Mar 2016, 06:33 pm
If the engine was running even badly after things got wet maybe let it dry a day with the hood open. Out of the rain that is.
You could also check for DTC's. (engine Codes). This may at least tell you what is not liking the water on or in it?
The other member had a good thought but you would have gotten an engine light and a subsequent DTC relating to one or more cylinder's miss firing.
We (most of us) all wash our engine and some of us soak them pretty good and the engine start and run just fine. most of the time. lol So chances are you just need to let things dry a little longer.
Old 15 Mar 2016, 06:43 pm
LionPT's Avatar
Do not remove the plugs themselves...just pull the wires & use a rag to soak up any water that might be in the plug wells. If you have water there & remove the plugs, you'll cause more problems & will have to drain the oil.
Also check the air cleaner box & filter. Check the PDC/TIPM by removing the cover & see if you have any water or moisture covering the fuses.
ColTED, buddyiramae and chuzz like this.
Old 15 Mar 2016, 07:20 pm
ditto on these....would also be nice if you have an air compressor....
Old 16 Mar 2016, 08:45 am
Water in the air box can cause problems for sure. For some reason, cars don't see to run too good on water injection!
Old 16 Mar 2016, 02:37 pm
Ok thank you all for the help!!! Really. thanks.
I"ll check all these today and post an update!
buddyiramae likes this.
Old 16 Mar 2016, 02:44 pm
Fk5 Fk5 is offline
Remember you can spray WD40 on stuff. The WD stands for water displacement. That is what you sprayed inside your distributor cap when it got wet.
chuzz likes this.
2003 GT 5 speed
162,000 miles
Tags
hood, rain, wet
Rain Problem fvargas PT Cruiser Convertible Forum 0 03 Jun 2013 07:05 pm
how well do HID's do in the rain? bryman Exterior Accessories Forum 2 02 May 2012 08:01 pm
Rain Rain Go Away..Sunny tommorow careyk General PT Cruiser Discussions 2 23 Jun 2008 08:26 am
ick Rain jmack General PT Cruiser Discussions 3 27 Mar 2005 11:27 pm
After The Rain robinjoe General PT Cruiser Discussions 4 02 Jun 2004 08:36 am
