This morning I tried turning on my hazards with the engine off and got nothing. When I turned the engine on they came on and wouldn't turn off, after trying to turn them off and on a few times they finally went off but only the right side, left side of the car was still blinking. So I turned the car off and on, blinker off and on. Finally got them to shut off. Went to work, blinkers worked fine, hazards still don't want to turn off after turning them on, with the engine on. They won't work at all with the engine off. What could it be? Btw, I also have the typical non working fog lights, I removed fog light fuse because the stalk smokes other wise.
Is there a relay and fuse for the hazards and if so are they the same relay and fuse for the blinkers? I recently replaced the horn relay too. I wanted to say, I recently got this car and ever since I got it I've noticed the blinkers make a distinct clicking sound when activated different from other cars as if they're about to die or they're staining if that makes any sense. Last edited by cloudhidd3n; 16 Mar 2016 at 12:21 pm. |
Yea I'll call around to find a mfs
Okay so local auto store has the mfs on hold to pick up after work. I Would like to check the relay s and fuse to rule those out first, anyone know where they are located? Also isn't there a Flasher on the mfs that I might need as well?
Edit: napa has it for $80 for napa brand, comes with stalk, hazard button whole assembly. O reilly auto parts has the same thing but different brand for $58. Which do i trust? Last edited by cloudhidd3n; 16 Mar 2016 at 02:37 pm. |
On second read, I can see what you said about your fogs. Almost all of us have had the problem with the MFS and fog lights, but a "smoking stalk" seems a little scary. I would look for burnt wires when you are in there.
2003 GT 5 speed 162,000 miles Last edited by Fk5; 16 Mar 2016 at 02:42 pm. Reason: Electrical guru, sanatanadharma is going to give better MFS advice than me! |
Because Trump
So sanata, do you think the mfs will fix this?
More inclined to suggest trying a different flasher... (added edit) rather than the Trump selected.
That was my initial thought, but he indicated that he already had the fog light issue and "smoke from the stalk." You stated that the flasher is mounted to the MFS. Wouldn't that indicate that he should swap the MFS and the flasher?
2003 GT 5 speed 162,000 miles |
Thank you guys, it was the mfs. Everything works now, even my fog lights! Last question, when using my blinkers why do I hear my blinkers clicking through my speakers when my radio is turned up?
Thread Tools | |
Display Modes | |
2006 Cruiser Turn signals and Hazards | libilou | Tech & Performance Forum | 28 | 17 Sep 2014 05:21 am |
No turn signals. Fuse Blows when Hazards turned off | JerryJovi | Northwest PT Forum | 1 | 15 May 2014 08:16 pm |
INDICATORS TURN SIGNALS HAZARDS | PATGAS | Tech & Performance Forum | 9 | 29 Oct 2013 04:59 pm |
Hazards and Turn signals out. | KrisBo | Tech & Performance Forum | 4 | 29 Dec 2011 05:23 pm |
Blinkers and Hazards not working | badgingles | Tech & Performance Forum | 1 | 03 Sep 2009 08:55 pm |
