horn issues
Like Tree4Likes
Old 17 Mar 2016, 08:09 pm
Default horn issues
Did I buy a lemon or is this typcal pt cruiser stuff? Anyways, a week ago my horn stopped working, I diagnosed the relay, Replaced it, worked fine..now again it's not working and its not the relay, this time the alarm still works, I can set it off by opening the locked doors from the inside. But the horn won't work. Dunno if this is related but yesterday I replaced the mfs to fix my fog lights and hazards. Any ideas?
Edit; okay wtf! I just punched the steering wheel and it worked. Seems it works intermittently when it wants to if I hit the horn hard enough.
Handy_Cruiser likes this.
Old 17 Mar 2016, 08:20 pm
Handy_Cruiser's Avatar
Default Re: horn issues
You might have a clock-spring issue. But if it was me and if I had recently installed a mutlifunction switch, I'd take the covers back off the column and assure everything was plugged up good. I'd likely unplug everything, clean the plugs and then plug them back in. I'd pay close attention to the plug for the clock-spring and I'd assure I hadn't damaged any of the wires going to it.
cloudhidd3n likes this.
Old 17 Mar 2016, 08:25 pm
You're right, i just did that, rechecked all the plugs, which one is the spring plug? So after a few good hits and punches, my horn works again..
Old 17 Mar 2016, 08:33 pm
Old 17 Mar 2016, 08:51 pm
Yea! Number 3 is what I messed with just now and works Again, for now..
Old 18 Mar 2016, 07:09 am
Any way you can put a small zip tie around the whole thing to keep it tight?
Old 23 Apr 2017, 06:58 pm
This problem still hasn't been solved. I opened up my steering wheel hoping I could find some sticky horn buttons but turns out they're in front of the air bag. Not able to get to it as you can see from the picture.
Basically I have to smack the horn really hard once or twice and then it'll work but eventually stops working again and then have to smack it to get it start working again.
Old 24 Apr 2017, 09:58 pm
Following this one... My 2007 horn sticks sometimes. The first time I honked the horn was probably 6 months after I bought the car. It stuck for a good 2 minutes. Mow, I just hit the horn again and it stops. So far, at least.
Old 24 Apr 2017, 10:30 pm
rckstein's Avatar
This part has been replaced on my PT 3 times, for the horn pad sticking, the first time just 5 months after I purchased my PT:
MOPAR 68002385AA
But I can't find a good diagram of where it actually goes.
The clock spring has also been replaced, but I don't know if the clock spring is related to the horn switch. It was replaced because of the airbag light.
Old 14 May 2017, 02:37 pm
At this point I just need to install an aftermarket horn and new button somewhere, or maybe just a new button rewiring, disconnecting the old horn button on the steering wheel. Any ideas guys? I hate not having a reliable horn, and now my clock spring is making noise too when rotating the wheel I hear a slight "tick/click".
Horn Issues terryb8388 General PT Cruiser Discussions 3 03 May 2015 04:50 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
My horn :( ucantcme General PT Cruiser Discussions 10 27 Jun 2008 02:12 pm
New Horn Sandy-GRR8PT General PT Cruiser Discussions 11 06 Apr 2006 08:40 am
A-uo-Ga Horn turbomangt General PT Cruiser Discussions 14 06 Feb 2003 10:01 am
