p0340 code. Question about the inner part of the sensor
Like Tree6Likes
Old 18 Mar 2016, 08:48 pm
podo2000's Avatar
Default p0340 code. Question about the inner part of the sensor
Got a p0340 code. Car just died in parking lot. Changed out the sensor but no joy. Turned the car over but without the sensor on and the inner magnet isnt spinning. Would the timing belt have broken?
2004 PTGT 135Kmiles
Old 18 Mar 2016, 09:26 pm
LionPT's Avatar
Default Re: p0340 code. Question about the inner part of the sensor
I hope you have some money saved up...
Old 18 Mar 2016, 09:31 pm
podo2000's Avatar
So most likely timing belt?
Just had the belt done 28k miles ago
2004 PTGT 135Kmiles
Old 18 Mar 2016, 09:54 pm
LionPT's Avatar
I'd pull the cover & check to be sure.
Old 18 Mar 2016, 10:25 pm
podo2000's Avatar
Will do that in the am. Thanks
2004 PTGT 135Kmiles
Old 19 Mar 2016, 01:06 pm
podo2000's Avatar
The belt had snapped. Will i have to check the heads for valve damage?
2004 PTGT 135Kmiles
Old 19 Mar 2016, 01:19 pm
LionPT's Avatar
No, there fine.
Replace the belt, idler pulley & water pump.
podo2000 likes this.
Old 19 Mar 2016, 01:20 pm
Take it apart and replace the belt then do a compression check before you start putting it all back together.
Maybe who changed the belt said they did????
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 19 Mar 2016, 01:30 pm
rckstein's Avatar
Who did the previous replacement, what level of shop? What other parts were replaced at the same time? How many miles did the vehicle have on it when the first belt was replaced?
JoeX likes this.
Old 19 Mar 2016, 02:01 pm
if you're going to replace all of the timing components and water pump, you should really go ahead and replace the center motor mount too.
rckstein, podo2000 and JoeX like this.
Cam sensor P0340 code question MOTORCITYBADBOY Tech & Performance Forum 4 19 May 2014 04:12 pm
Cam Sensor Problem?? P0340 mcupkim General PT Cruiser Discussions 17 20 Oct 2013 10:40 pm
P0340 cam sensor code in 2006 cruiser deighter Tech & Performance Forum 13 12 Jan 2012 07:41 am
Code P0340 Cam Shaft Position Sensor A Dsmsta187 General PT Cruiser Discussions 6 13 Apr 2010 09:01 pm
Code P0340 Cam Shaft Position Sensor A Leroy Western PT Forum 4 02 Apr 2010 04:01 pm
