Several weeks ago, I had a tire blowout on me, causing me to smack a curb with my front right tire pretty hard. I got all 4 tires rebalanced afterward and all seemed fine except for a small scratching sound, which we assumed was the brakes and was temporarily fixed by liberal application of brake cleaner, and a belt squealing that had been going on for awhile. It car was fine until two days ago, when it suddenly began to grind/clunk VERY badly while driving. Stopping and letting the car sit for approx. 10 minutes fixed it temporarily. The tech at my local AutoZone suggested it could be a ton of things but especially the idler pulley or water pump. Here's where it gets weird: on my way home, I smacked a pothole HARD...and the noise stopped! Now it's back to its regular scratching sound.
Anyone have this happen and have an idea what might have caused/fixed it? |
![]() Quote:
2003 GT 5 speed 162,000 miles |
It is silent at idle, and seems to go with the wheels/steering. I'll have to check out the wheel bearing I suppose.
I don't mean to smack potholes, but they just jump into my way. |
Maybe you've damaged an axle. Check the boots to make sure none are cracked and slinging grease.
![]() Aspire to inspire before you expire. |
Ignore it. It will go away.
I have been "ignoring" a squeaky alternator belt for almost 3 years. it comes and goes, but any time that it is damp out, it is squeak city. A friend says that once you get coolant on a belt they will do that. At some point I will get in there and change it, but until then... what is the radio for?
I had a similar noise. The small sheet metal carrier that the front brake pads sit in and supposedly slide on were extending past the pads as they wore and were slightly scratching the rotor. Very irritating noise. I had to disassemble the front pads and bend the sheet metal carriers out a little. No more noise. Usually worse when turning on direction or the other.
Thread Tools | |
Display Modes | |
She's finally home!!! | Hokie_Phd | General PT Cruiser Discussions | 16 | 19 Apr 2013 04:47 am |
the car is home !! | bobs turbo pt | General Turbo Discussions | 9 | 21 Apr 2003 07:02 pm |
