2006 PT Cruiser A/C and Fan Maybe Problem
Old 01 Apr 2016, 08:09 pm
Default 2006 PT Cruiser A/C and Fan Maybe Problem
I found out the other day the pt cruiser I bought doesn't have any a/c along with the battery light coming on. I took it to one mechanic and they said that I need a compressor and some other items.
Mechanic stated that the high side was 400 and the low side was higher than 100, I believe. So he said the compressor was being bypassed causing my engine to shake really bad when the ac is turned on. Instead of trying to find out if one is bad or ect. I need to replace it all which makes no sense to me. It would cost more than 1,000. To me a mechanic should be able to narrow down what is the bad part and replace it.
Then I took it to pep boys and they tell me that my fan is bad. I had my fan checked before and a sensor was replaced. I'm not sure who to believe because I turned on the ac and I heard the fan running. I can't be without air
A/C Info:
Hear fan running when I turn on a/c
Just blows hot air
I hear compressor click
Both places said Freon is good
Old 01 Apr 2016, 08:24 pm
Default Re: 2006 PT Cruiser A/C and Fan Maybe Problem
A/C Info:
Just blows hot air
The 100 on the low side with the compressor running is high I believe and could be caused by the fan startiing to fail. In other words, your fan may be running but not as it should be.
Please tell us the mileage and engine, type, Turbo or not turbo. Is your car overheating in traffic( avoid over heating the engine or you could run into major $$$).
IF the temperature gauge EVER goes past half way to hot, you have a problem.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Apr 2016, 09:53 pm
Is your engine light on? If so what is the engine trouble codes?
I agree with JoeX. When was the last time the radiator fan was replaced? I even keep a spare radiator fan in my garage in case I need it immediately. You never want to have a radiator fan completely fail on you. The consequences is too expensive.
Old 04 Apr 2016, 01:35 am
Its a non turbo. Its usually in between hot and cold. I bought the car last year. It has 100,000 miles.
Old 04 Apr 2016, 01:37 am
Not sure engine type. Just have the regular basic 2006 pt cruiser.
Old 18 Apr 2016, 11:24 am
I found out my fan was working when I took it to another mechanic. Also, there was a leak in a hose that this mechanic found and the other 3 or 4 mechanics wasn't able to locate. My latest problem is that the car shakes really really bad when I turn the air conditioner on. This mechanic said I need to do a throttle clean which would help the shaking. Is this true?
Old 18 Apr 2016, 11:27 am
I thought maybe the fan could be the problem why the engine shakes so much. I was thinking the low speed on the fan wasn't working but the mechanic told me that non turbo pt cruisers don't have 2 speed fans so that is not my problem why it is shaking so bad.
Old 18 Apr 2016, 11:48 am
rckstein's Avatar
LionPT likes this.
Last edited by rckstein; 25 Apr 2016 at 11:52 pm. Reason: Removed because some other member wants to run the entire forum
Old 18 Apr 2016, 02:07 pm
If the fan is not working correctly and engine shakes with air on its because pressure in AC system goes up causing a heavier load on engine.. shake- shake -shake
73 Charger SE
01 Sebring flip
Old 19 Apr 2016, 08:36 pm
Will try a fan and see what happens.
2006 PT cruiser charging problem pappynoodle Tech & Performance Forum 1 05 Nov 2015 04:22 pm
2006 pt cruiser windshield wiper problem Benjamin9669 Tech & Performance Forum 2 06 Nov 2014 05:04 pm
2006 cruiser starting problem Cruiser54 Tech & Performance Forum 1 03 Apr 2013 05:34 pm
2006 cruiser rear wiper problem wherley Tech & Performance Forum 6 30 Jul 2012 11:02 pm
2006 pt cruiser idle n loss of power problem chickon35 Tech & Performance Forum 4 30 Sep 2007 04:35 pm
