does it stink like coolant?
Nope. Though it is hard to tell as I last filled up with just water as I was losing so much. A valve went kapput, had it fixed but then had over heating issues.
The water on the floor though appears most wet from the side kick panel rather than from the top of the foot well area.
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0 ![]() ![]() |
If it looks like it's coming in from under the kick panel, I'd check the cowl (plastic pieces under the wipers) for a lot of debris. If you have a lot of leaves and crap in there, the cowl can't drain properly and the water will run inside the car. It could also just be a clogged a/c drain tube. Clean it out and see what happens. And of course you're going to have overheating issues with just water in it, you wanker
![]() Aspire to inspire before you expire. Last edited by chuzz; 02 Apr 2016 at 05:52 pm. |
Easy to diagnose.
With windows closed spray your windshield with water. Is the floor damp? Repeat with water over the sunroof and the door. Add antifreeze to your radiator. After running the car for a while does the fluid on the floor smell like antifreeze? (most likely heater core if it does) |
![]() Quote:
At first I thought it was heavy rain, it rains almost every day of the year where I am, however, the carpet was drenched after a few days of actual clear weather so I ruled that out. I just checked the carpet now after i put in my mix of anti freeze and it doesn't smell of anti freeze. Though that is vanishing somewhere. Can't be a seal issue as we have not had rain for a few days now.
Thread Tools | |
Display Modes | |
Heater Core? | scatgo1 | Tech & Performance Forum | 12 | 09 Jan 2016 10:49 am |
Heater Core | JLMullins | General PT Cruiser Discussions | 3 | 15 Aug 2015 09:31 pm |
Heater core | TMas777 | Tech & Performance Forum | 8 | 13 Oct 2011 04:31 pm |
Leaking Heater Core? | chuck2112 | Tech & Performance Forum | 1 | 20 Nov 2010 04:39 pm |
