Brake Lights Stay On
Like Tree3Likes
Old 05 Apr 2016, 01:42 pm
Send a message via AIM to rcalzadilla Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default Brake Lights Stay On
Brake and Third lights stay on with engine off and key off the ignition.
Took Brake Light Switch off: Brake and third light now off of course.
Can't find an elec schematic for switch but these pins (switch disconnected) have continuity:
Pink/Blue line and White/Gold the rest do not.
Help, this wife's car!
Old 05 Apr 2016, 02:58 pm
Default Re: Brake Lights Stay On
Because Trump
LionPT likes this.
Old 05 Apr 2016, 03:08 pm
The lever on the side of the new brake switch should not be turned until after the new switch is installed.
chuzz likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 05 Apr 2016, 08:59 pm
What year is the PT Cruiser?
Has any repairs been done to it lately?
Old 06 Apr 2016, 10:58 am
2001 model year.
No repairs have been done lately.
Old 06 Apr 2016, 02:38 pm
I have put in a new switch and now stop lights go on and off as normal.
Have checked out the old switch as per Service Manual, see attachment and it works correctly. But have decided to change the switch anyway.
Still I don't know how power was transmitted with three separate switches inside and the plunger/selector is plastic. Don't see a relay in the circuit.
Attached photos how clean/pristine inside; nothing broken either.
Old 06 Apr 2016, 03:19 pm
I believe: Please I'm no master at this so correct me if I'm wrong
1 is for brake lights
1 is for cruise shut down
1 is third brake light through computer
Turning the little lever after the brake switch is install sets the adjustment for the plunger to the brake pedal.
If your a good tinkerer you can take the brake switch apart study it and reset it to be used again. I've done it. But they cost only $10.00
73 Charger SE
01 Sebring flip
Old 06 Apr 2016, 03:54 pm
Fk5 Fk5 is offline
Not to hijack, but how hard do you think it would be to rig up one of those switches to the clutch to cancel the cruise when the clutch is depressed? The highest my car has every revved was when I put it in neutral with the cruise on. Even floorboarding the clutch won't cancel it.
Worse, my other cars with cruise all do cancel with the clutch. Guess this is just dreaming because there are about 44 other items to correct before I start making improvements.
2003 GT 5 speed
162,000 miles
Old 06 Apr 2016, 04:25 pm
Because Trump
Old 06 Apr 2016, 08:12 pm
The wiring schematic shows a PK/DB wire coming from the battery to Fuse #12 to the brake switch on page 8W-30-27 from the shop manual. This gives the brake switch a constant 12 volts.
Interior lights stay on????? cruisergeo Tech & Performance Forum 11 28 Oct 2016 03:58 pm
Fog Lights and interior lights stay on kevinmellett General PT Cruiser Discussions 10 24 Nov 2014 10:54 am
Traction control, ABS, and Brake lights stay on RHCruiser Tech & Performance Forum 4 11 Sep 2013 05:35 pm
2003 interior lights stay on RLS7201 Interior Accessories Forum 7 13 Mar 2011 09:59 pm
Interior Lights Stay on skirevskip Tech & Performance Forum 1 13 Mar 2011 07:52 pm
