2 questions that are probably common but there is so much garbage on the net that I'm having a hard time finding the info I need.
I need a transmission filter change and I have a kit that I picked up a while back and I want to make damn sure it's the right one before I drop the pan. I think there are 2 transmissions I could have... it's a 2006 automatic base model 2.4 non turbo. How can I I.D. my transmission? Secondly: I also want to renew my coolant. Rumor is that the H.O.A.T coolant is a mopar scam and you can just use prestone "all makes/all models" type coolant and it's perfectly fine. Is that true? Thank you in advance. |
![]() Quote:
I am suggesting you replace the coolant with the same coolant from the dealer that is in the PT Cruiser. The question is how often are you going to change the coolant and why take a chance on any other coolant that might not be compatible. I have friends of mine that decided to try and save a few dollars and now they have a clogged coolant system with brown residue from mixing two different coolants.
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 07 Apr 2016 at 12:02 am. |
I would be worried about any kind of coolant. Do you have any way of being sure what is in there now? AFAIK, while they are supposed to be universally compatible, you shouldn't mix them. If it were me, I would wait until the summer and then flush it a few times with distilled water and then use the coolant you decide is best.
We are the original owners of mine, but when we got the radiator done I couldn't tell what they had in there. I just waited until it was warm and kept draining, disposing and filling with distilled water. When I was sure all the old was out, I went back to coolant. I went with the Zerex/Valvoline G-05 because that is "general consensus" but whatever you do, I wouldn't mix. Of course two months after I was finally done the "new" radiator started weeping. Ugh.
2003 GT 5 speed 162,000 miles Last edited by Fk5; 07 Apr 2016 at 08:36 am. |
![]() Quote:
Forgive my ignorance, but what is the benefit of using distilled water?
![]() 2002 2.4L Woody Normally aspirated Purchased 2/29/16 w/ 104,048 miles |
Welcome to the forum
you don't really need distilled water..........look up what antifreeze does. ![]() |
Just an extra safety measure if you have hard water. I'm sure tap water is fine, but for 85 cents I'll use the distilled.
2003 GT 5 speed 162,000 miles |
Distilled water is not really necessary due to part of the coolants property is to protect against any minerals in normal tap water that could form corrosive build up.
If at First You Don't Succeed - Try, Try Again |
My dealer had a coolant system service flush/fill for $99. I had both my PT and my Ram Pickup done a few years back. I think the manual says 5 years on the coolant. Both my rigs are 2006.
Like I said, I'm sure it is not a big deal, but I generally run straight water for a time while I am making sure all of the old coolant is out of it.
![]() Quote:
Thread Tools | |
Display Modes | |
Coolant questions! | yenciny | General PT Cruiser Discussions | 19 | 10 Nov 2013 07:30 pm |
Coolant flush questions. | konadave | Tech & Performance Forum | 5 | 15 Jul 2013 03:56 am |
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap | MarcusO | Tech & Performance Forum | 7 | 27 Apr 2013 09:16 am |
Replaceing PT cruiser Trans- Prepping trans questions | Wiredright | Tech & Performance Forum | 6 | 13 Feb 2013 10:59 am |
Flushed the coolant today, got questions. | Dill | Tech & Performance Forum | 12 | 12 Jun 2011 11:44 am |
