Radiator Cap Choice
Like Tree3Likes
Old 07 Apr 2016, 03:20 pm
Default Radiator Cap Choice
Okay Guys, I think I'm going to get another radiator cap for the GT. I did hear a little gurgle in the overflow this morning after driving about 30 miles, but it quickly stopped. Lasted maybe 30 seconds. So, I'm pretty sure it's the cap. It currently has a lever type on it and for some reason, the damn lever doesn't want to stay put. I'm thinking I'll just put a regular cap on it this time. What say you gurus of the PT's? I'm also pretty sure it's a 16 pound pressure cap that I need, not a 14, right?
Old 07 Apr 2016, 04:50 pm
Default Re: Radiator Cap Choice
I think it's a 17 or 18 psi you need. Just a standard cap. Nothing fancy.
Old 07 Apr 2016, 06:23 pm
I use 18psi but then I am cooling system check for that pressure and I also run a 180F thermostat
17psi is the standard for most all PT Cruisers with 2.4 US models.
Either way I don't like the level pressure release radiator coolant caps.
Old 07 Apr 2016, 09:40 pm
All of the turbo PTs, at least 03-05 came from the factory with an 18lb cap.(I didn't check the second gen cars, but they are likely the same 18lb). All of the 03-05 Naturally Aspirated PTs came with 16lb caps. (likely every year NA cars used 16lbs, but I didn't check them.
Old 08 Apr 2016, 12:09 am
The factory manual part number for this radiator cap indicates 17 PSI for 2003 Turbo.
Old 08 Apr 2016, 06:47 am
Thanks for the replies. I think I'm going to go with the 17lb non lever type. I sure hope that cures the bubbling issue. It's driving me nuts. Short drive, I know.
Fk5 likes this.
Old 08 Apr 2016, 06:52 am
Fk5 Fk5 is offline
I could have sworn that mine had an even #. Either 16 or 18. I can probably check. Pretty sure that I have the original cap in my tool box. I swapped it before the radiator went the first time. My problem wasn't the cap. How bad is it bubbling? Mine did that a bit when it was getting burped or when the temps were getting a bit high. Good luck.
2003 GT 5 speed
162,000 miles
Old 08 Apr 2016, 07:16 am
I just checked again for a 2003 turbo. The factory manual part number is 52028974AA, and it is an 18lb cap.
Here is a picture. If you look closely you can see the part number as well as the rating. The part number is hard to see but if you enlarge and turn your screen brightness up, you can see that indeed it is the correct part number and not simply a 'stock' photo:
Old 08 Apr 2016, 08:15 am
There is another number for the radiator cap 04596198. We are down to 04596198 for engine EDZ that says 17 PSI or 52028974AA for engine EDV that says 18 PSI.
Old 08 Apr 2016, 08:17 am
There is another number for the radiator cap 04596198. We are down to 04596198 for engine EDZ that says 17 PSI or 52028974AA for engine EDV that says 18 PSI. If I was to choose between the two and I had a 2003 PT Cruiser I would choose 17 PSI.
A unique choice 2008ptcruzrtouring General PT Cruiser Discussions 13 27 Mar 2015 07:42 am
Headlamp replacement (choice) kctobyjoe General PT Cruiser Discussions 15 17 Mar 2014 07:29 pm
DC2 going to be going bye bye...not by my choice... tangerine03 General PT Cruiser Discussions 12 30 Dec 2011 09:59 pm
Best Tire Choice? Ironman Tech & Performance Forum 7 07 Sep 2008 10:22 am
Winners Choice Products Winners Choice Products Vendors & Buyers Forum 2 07 Sep 2001 12:53 am
