Why I should check my oil regularly. Typical leak locations?
Like Tree3Likes
Old 10 Apr 2016, 10:19 am
Flash619's Avatar
Default Why I should check my oil regularly. Typical leak locations?
So the other day I come to a stop sign, and my oil light turns on for a few seconds then turns off. I figured 'well, probably low and oil is moving around from the momentum of the stop. I'll check it when I get home.' So I get home and pull out the dipstick. It was completely bone dry. I mean, I had no oil spots in any of my parking locations, so I was fairly confused at this point.
After dumping in a quart of oil, I had a very small amount on the tip of the dip stick. In total, it was 3 quarts low. I ran it through with some cleaner for a while, to get out any internal gunk from it running so low, then drained and refilled the entire engine oil (including a new mopar filter).
So far it seems to be running fine, and the level seems to be sticking, but does anyone else have any similar experiences? I'm wondering if I could have a leaky camshaft seal. Underneath the pan, I didn't see a bunch of oil down the passenger side, but instead, tons of sludge seemed to come around the side of the passenger side from above the oil pan location, but not near the crankshaft (so probably not a crank seal).
I included a picture of after adding one quart. Not going to lie, I feel lucky I caught it before it blew something.
Old 10 Apr 2016, 10:33 am
Default Re: Why I should check my oil regularly. Typical leak locations?
If you can't see a leak, two things could be happening. A small amount at a time is getting into the combustion chamber through a crack in the head gasket and being burned. Not enough to cause smoke to be seen out of the tail pipe or a small bit of oil could be leaking in or around the exhaust manifold and burning away. My thought anyway.
Old 10 Apr 2016, 10:49 am
After running you car for while, put a big sheet of cardboard under the car and look at it after an hour or so to look for oil drips.
Is your air filter oily? Could be bad PCV - cheap and easy to replace.
How long since oil was at full mark?
Old 10 Apr 2016, 10:51 am
Although you are not installing Performance parts much of this information about basic engine checking while common sense we sometimes don't always think about when small problem like oil consumption happens.
Adding Perfromance PT CRUISER parts
PT problems read this FIRST
Old 10 Apr 2016, 12:37 pm
I would suggest you take the passenger side tire off and take the panel off inside the fender. This will help you find the oil leak. It can possibly come from a valve cover gasket leak, camshaft leak, etc.
Old 10 Apr 2016, 12:41 pm
Flash619's Avatar
I did the cardboard thing last week when I filled it, didn't see any dripping marks. How long was it since it was last at the full mark? That's an excellent question, my assumption would be, too long. I was busy a lot in the last few months and don't honestly think I changed it since last fall/early winter.
I don't see any leaks around the valve cover gasket, I did just replace that last year. :/
Old 10 Apr 2016, 12:48 pm
Miles probably more important than time...
If car was sitting, THEN you put cardboard under, you likely won't get anything - you need to run car and put cardboard under right away to catch a leak - and it might not be leaking, just burning the oil.
Old 10 Apr 2016, 01:13 pm
While the cardboard works for coolant it does not work as well with finding oil leaks. The main reason is the engine in most cases is very dirty so even freshly leaking oil will get soaked up in the dirty engine and will take time before it reaches the ground. And then it will also travel like a river flows finding an easy path at first directed by gravity and then as it travels downward altered with with what gets in the way old oil and dirt.
To find an oil leak you really should thoroughly clean the engine with down first.
Another way is to look for the oil leak is at night or in the garage as dark as possible. Using a flash light will make pin point the "wet" fresh oil much easier then looking in an illuminated environment.
Old 10 Apr 2016, 01:17 pm
Never tried that one. Did you mean Downy?
Old 10 Apr 2016, 01:26 pm
I didn't catch that....
it was suppose to say with "SIMPLE GREEN"
but your response was....
Air Bag locations iBorg PT Cruiser Convertible Forum 0 21 Oct 2013 09:25 pm
non typical blown head gasket zipps Tech & Performance Forum 7 28 May 2012 10:30 pm
Why won't my 2001 PT start regularly EnvisionMan Tech & Performance Forum 9 25 Jul 2011 11:14 am
Jack locations ptal General PT Cruiser Discussions 2 30 Nov 2009 01:25 pm
Funny (now), but typical for me PTGT Redman General Turbo Discussions 12 08 Jun 2004 10:11 pm
