starts but won't run after repairs
Like Tree2Likes
Old 14 Apr 2016, 09:42 am
Exclamation starts but won't run after repairs
Hey everyone,
I am working on my friend from out of town's 04 automatic cruiser and after finishing repairs it will start fine but idles very low. if you push the accelerator
it will tac up then down and up and down very quickly. after putting it in drive even when giving it gas it dies after rolling a few feet. The initial problem was a leak in the pressure line out of the bottom of the power steering pump. The details of work done are as follows:
-Removed radiator
-removed serpentine belt and power steering pump
-reinstalled pump and new belt
-replaced pressure line (The pressure line going into the rack and pinion
took about 3 hours to break loose. had to remove air box and fuse box, the maf sensor got removed and reinserted a few times)
-replaced battery connection (battery had died and had to be jumped)
-reinstalled and bled radiator, filled with distilled water... planning to flush and put new coolant in)
-started engine, loud sucking noise. found the vacuum line from the brake booster got unhooked, reattached it and noise stopped
-attempted to test drive and found said problem
to me it seems like a vacuum leak issue but i have put everything back together correctly. I doubt it is spark plugs or fuel filter since it was running ok beforehand. any help is greatly appreciated as she has had to call out of work a few days already and needs to get home.
Thanks in advance guys.
Old 14 Apr 2016, 09:45 am
Default Re: starts but won't run after repairs
FYI no codes but check engine light and oil light are on now.
Old 14 Apr 2016, 10:50 am
LionPT's Avatar
If the CEL is on, there has to be a code.
Old 14 Apr 2016, 01:04 pm
Hmm. The only thing that displays when I run a code check is "done"
I think I'm going to fog the engine bay with carb cleaner and start it from cold to see if it revs. It has to be a vacuum leak somewhere.
Old 14 Apr 2016, 01:09 pm
Fk5 Fk5 is offline
The key dance is really useful, but there are times that it doesn't show everything. In my experience, I have never had a CEL without the key dance showing something, but many times the key dance has not shown a code that shows up on the code reader - and I never used a really good reader. I would try to borrow one.
Vacuum leaks are probably a good place to check. I know you have done this, but recheck everything that you did. You went through a bunch of stuff. Pretty easy to damage wiring or vacuum hoses.
2003 GT 5 speed
162,000 miles
Old 14 Apr 2016, 01:24 pm
Check the MAF and associated wiring. Even though it sounds like a vacuum leak to me too, I'm thinking if it was one that large, you'd be able to hear it. But then again, I'm not a mechanic, so what do I know?
Old 14 Apr 2016, 01:32 pm
Fk5 Fk5 is offline
Should we just put that in our signatures?
rockandroller likes this.
2003 GT 5 speed
162,000 miles
Old 14 Apr 2016, 01:46 pm
I don't know about you, man, but it's a pretty good idea for me!
Fk5 likes this.
Old 14 Apr 2016, 02:17 pm
LOL Key Dance I dig that. I will do a thorough dummy check and use the carb cleaner. If I can't figure it out with the preliminary stuff I'll borrow a reader from a parts store and see where that gets me.
Old 14 Apr 2016, 02:28 pm
I feel you! I don't think I qualify as "shade tree mechanic" just yet lol.
Tags
acceleration problem, idle problem, rough idle, vacuum leak
engin runs rough at operating temp ,starts fine but starts to buck when you give it t moby General PT Cruiser Discussions 1 01 Oct 2014 06:57 pm
Shop Repairs rckstein General PT Cruiser Discussions 10 01 Jul 2014 11:04 am
more repairs needed dpmeeks General PT Cruiser Discussions 8 02 Dec 2011 01:46 pm
01 PT Cruiser repairs 2ndPTC Tech & Performance Forum 4 08 Apr 2011 02:13 pm
REPAIRS at 65k Teekypt Turbo Wheels/Suspension/Handling 17 21 Aug 2008 11:22 pm
