2006 Pt Cruiser NA will not crank until new PCM
Old 15 Apr 2016, 08:46 pm
Default 2006 Pt Cruiser NA will not crank until new PCM
My 2006 Cruiser NA had a replacement computer about 5000 miles ago from a place that sent me 3 0r 4 bad ones first.After the last one they said warrantee is up because they sent me to many computers. Low and behold the last one they sent cleared all but one code for O2 voltage high which turned out to be a bad ground at the eyelet on the left fender. Drove it for 5000 miles and it sputtered about 6 blocks from home before taking its last breath. I checked most everything mentioned here. I wasn't in a hurry to fix the car so I let it set and looked locally for a PCM / SKIM/ key out of the same 2006 and contacted many on Craigs list but usually there were no replys.
Symptoms were: No crank, and sometimes the little round security light would
come on and sometimes not. There were no codes, just done.
If I held the key in the start position, sometimes the starter would operated just long enough to move the crank a little. I suspected the PCM or TIPM.
Since my Security light was coming on I thought the problem to be with the SKIM module and computer.
Finally a few weeks ago I saw a post by NiTro I believe sbout SYKED ECM Tuning in Washington state and sent my PCM to SKYED eliminate the security process. It turned out to be my PCM was bad but just happen SKYED received a PCM from another person to be flashed For a Turbo. They sent a NA PCM not realizing the difference and with the help of SYKED I purchased the PCM from the guy needing one for a Turbo. I received the PCM this afternoon and in 15 minutes my 2006 Pt Cruiser roared back to life.
Less security, less remote door locks.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 15 Apr 2016, 10:30 pm
Default Re: 2006 Pt Cruiser NA will not crank until new PCM
What place was sending you bad PCM's? Glad you got your PT Cruiser back on the road!
Old 16 Apr 2016, 01:34 am
The bad PCMs were from a company in Cary, North Carolina Car Computer Exchange and on their web site, their contact information names Imperial Car Computer Exchange.
When it went bad after just a few thousand miles, I didn't even contact them again because my last contact with them, they already said "No More".
Their one year Warranty , as they explained it to me was if it went bad with in that year they would replace it, and they felt they went far beyond their warranty by sending more than one.
I also got one from another company in Florida, I forgot their name, it also was bad but they accepted its return with a full refund.
73 Charger SE
01 Sebring flip
Old 16 Apr 2016, 05:25 am
Sounds to me like SYKED is the go to for PCM's. I HOPE I never have to replace mine, but that will be my choice. I've only heard good things about SYKED.
Old 16 Apr 2016, 06:30 am
SYkED doesn't repair or replace or sell PCM's, I just happen to to be lucky that a customer of theirs sent a PCM to SYKED for reprogramming. SYKED was going to return the PCM to its owner.
Check out their web site for their work.
Syked Ecu Tuning | Dodge Tuning Software
73 Charger SE
01 Sebring flip
2006 PT will not start at all! No crank, nothing! Cruiser72 Tech & Performance Forum 12 24 Aug 2014 04:59 pm
PT Cruiser engine won't crank scoobybug Tech & Performance Forum 7 24 Jun 2014 07:53 am
Cruiser won't crank Neen General PT Cruiser Discussions 9 06 Mar 2014 11:21 pm
02 Cruiser, won't crank ohwell Tech & Performance Forum 5 27 Jun 2012 09:14 pm
02 pt cruiser won't crank over. vanhalen7174 Tech & Performance Forum 2 04 Apr 2010 12:06 pm
