Should I replace the tranny?
Old 16 Apr 2016, 01:17 pm
Default Should I replace the tranny?
I finally picked up a second PT for my wife, a 2003 automatic with 114k miles. It had been sitting around for a while before the owner decided to sell it and was pretty dirty but otherwise ran okay except for a high rev going from 1st to 2nd (over 3000) and 2nd to 3rd (4000). The price of the car was lower than average, so I took a gamble that I could deal with the high revs and bought it.
I drained the tranny fluid and replaced the filter. The fluid wasn't burnt but there were more shavings on the magnet than I would have liked. No excess metal in the pan otherwise. Given the magnet bloom though, I'm thinking the tranny is not up to snuff and wondering if I should have it worked on or just replaced with a cheap used one? I already have to do a water pump/timing belt job (I just discovered the pump is leaking) so I have to solve the tranny issue for the lowest cost I can.
Old 16 Apr 2016, 02:25 pm
Default Re: Should I replace the tranny?
Is your engine light on?
If so what are the engine trouble codes?
Old 16 Apr 2016, 02:37 pm
No light and I'm not pulling any codes (the first thing I checked).
Old 16 Apr 2016, 03:58 pm
Before I would consider internal damage in the transmission I would check everything else that might cause your issue.
I would try unplugging all the plugs going into the PCM and see if you have moisture from sitting for several months or oil on the female plugs coming from the oil pressure sensor that might be causing your issue.
Also I would take the battery out, remove the battery support plate and see if the transmission wires are damaged from the battery acid over the years.
Old 16 Apr 2016, 04:10 pm
Thanks, I'll do that. The oil pressure switch was bad (leaking) and the connection on it had the wire pulled out so I already fixed both of those. I wasn't sure what to look for after changing the fluid/filter and examining the pan.
I do know that the shifts feel more like they're in the normal range after it's been running for a bit and the higher gears seem to have normal rpms regardless.
I'll update with what I find after I follow your suggestions. Thanks.
Old 16 Apr 2016, 04:49 pm
I pulled the plugs at the PCM but they seem fine.
I took out the battery plate and the plugs below don't look corroded. Everything down there is kind of covered in a mixture of oil and dirt, but no obvious corrosion, cut wires, or disconnections.
I should also add that the shift occurs normally if I left off the gas before the higher rpms. It's just the automatic shifting that seems to need to peak high.
Old 16 Apr 2016, 05:13 pm
I'll bet the valve body has a little varnish build up in it from sitting. Just drive it for a couple of weeks and I'll bet you that the shifts improve. The fluid you used was ATF+4, right? If not, then you're living on borrowed time.
Old 16 Apr 2016, 05:23 pm
I always ATF+4, having had nothing but Chryslers for the past 20 years. Can't say if that what the previous owners used though of course.
Old 17 Apr 2016, 06:49 am
I'd just drive it a few days and see if there's improvement.
Old 17 Apr 2016, 08:20 am
SvenCruiser's Avatar
Thats going to cost you more than the price of the car.
PT CRUISER 2.2 CRD Turbodiesel
Replace Crankshaft Sensor when you replace Cam Sensor falconut Tech & Performance Forum 7 14 Oct 2015 08:43 am
srt 4 tranny mattsptgt Tech & Performance Forum 3 03 May 2011 07:19 pm
Oil Leak...replace tranny hose mstyler05 Tech & Performance Forum 2 11 Jan 2011 12:11 am
Tranny or something else? Kawizx9r Tech & Performance Forum 5 04 Sep 2010 02:57 am
yea it's the tranny! atcocruiser Tech & Performance Forum 6 31 Dec 2007 08:36 pm
