'07 pt cruiser acceleration stumble
Old 18 Apr 2016, 01:44 pm
Default '07 pt cruiser acceleration stumble
My pt keep stumbling on acceleration between gears..i know it has something to do with the TRANSMISSION and i was told it's the vacuum line??!! I literally have to accelerate like a semi or let loose on the gas just before it switches into the next gear otherwise it stumble like its not catching..can somebody please help me on this matter or at least tell me where this mystery vacuum line is to the transmission??!! The car is well maintained and has 162,000 kms on it...
Old 18 Apr 2016, 01:59 pm
Default Re: '07 pt cruiser acceleration stumble
There are no vacuum lines to the transmission
You want to check your tubing and hoses on the engine for cracks.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 18 Apr 2016, 02:23 pm
Do you think that is the problem on why it stumbles??!!
Old 18 Apr 2016, 03:57 pm
Other things could make it stumble. Or are you talking that the rpms go up between shifts?
or is the engine loosing power.
old plugs, wrong plugs, gap to wide on plugs, old wires, coil miss fire, are you getting the engine service light?
any codes?
73 Charger SE
01 Sebring flip
Old 18 Apr 2016, 05:01 pm
Fixed the plugs n new wires used champion brand and gaps are to spec..could be old wiring i'm not sure, the engine actually is not getting enough power..it wants to go but something is blocking it. I got the fuel system cleaned and that is not the problem either, it just stumbles before it switches to the next gear..i have to let off the gas so it can catch..
Old 18 Apr 2016, 09:00 pm
Is your engine light on? If so what are the engine trouble codes?
Old 18 Apr 2016, 10:08 pm
Get up under it and tap the catalytic converter with a rubber mallet or light hammer. If you hear crap rattling around in there, your cat con is getting clogged up. Replace it.
Old 19 Apr 2016, 12:50 am
_PTGT03's Avatar
buy and install a cheap vacuum gauge to test for a plugged catalytic converter.
spark plug gapped ? secondary ignition coil wires tested for insulation leaks and resistances ? primary coil resistances ?
throttle position sensor within calibration ?
compression tested ?
timing belt installed properly ?
fuel system or injectors gummed out ? (try gum-out high mileage additive)
Old 19 Apr 2016, 04:15 pm
thank you everyone for your expertise in the matter and i believe it could be the catalytic converter...sounds legit lol but nevertheless keep your opinions coming and will update you all if this was the problem.
Oh and one more thing with the converter is it better to buy the one made for the pt cruiser?! I hear the universal ones you have to do alittle welding and that i don't want to do lol
2005 Pt Cruiser Gt Convertible - Jerking Acceleration jallen1026 Tech & Performance Forum 5 04 Mar 2016 01:31 pm
PT Cruiser high rpms and strange acceleration issues CarNoob85 Tech & Performance Forum 9 28 Jan 2014 09:50 pm
02 Pt Cruiser Over heating and smoking with heavy acceleration 02ptcruiser Tech & Performance Forum 6 22 Mar 2013 01:17 am
blows acceleration pt cruiser gt when gas fully open Dsound Tech & Performance Forum 5 26 Sep 2012 09:47 am
Engine Revs in Pulses with Full Acceleration - PT Cruiser ralpharino567 Tech & Performance Forum 5 23 Sep 2009 08:05 pm
