No High Beams or High Beam Indicator
Old 20 Apr 2016, 11:28 am
Default No High Beams or High Beam Indicator
Noticed a few days ago my high beams are not working, nor is the blue high beam indicator on my dash.
All fuses in the dash panel and underhood PDC check out fine. Low beams, wipers, signals, fogs, all work. When I pull the lever to turn on high beams, low beams (and fogs, if turned on) stay on.
High beams were working fine when I last used them a bit a week ago.
Removed, cleaned and reinstalled the MFS about three months ago when my fogs and associated dash indicator stopped working, no problems since.
What is more likely at this point, the headlamp relay or high beam bulbs? If both bulbs are shot, would that in turn prevent the dash indicator from coming on?
Thanks.
2004 Chrysler PT Cruiser Limited Edition Platinum Series 2.4L 4cyl Turbo
Old 20 Apr 2016, 12:53 pm
LionPT's Avatar
Default Re: No High Beams or High Beam Indicator
It's a little hard to follow what you posted....so,
When you push the lever forward you have no high beams or indicator...
What happens when you pull the lever backward, do the high beams work..??
Old 20 Apr 2016, 01:09 pm
Appreciate the quick response, please let me know what you would like me to clarify.
My high beams are normally activated by pulling the MFS lever towards me. From the manual:
Highbeam/Lowbeam Select Switch
Pull the Multi-Function Control Lever towards you to
switch the headlights to HIGH beam. Pull the control
lever a second time to switch the headlights to LOW
beam.
Currently, when I do this, neither the high beams, nor the high beam indicator on the dash come on.
Old 20 Apr 2016, 04:52 pm
LionPT's Avatar
So in the G1's there is only on & off, not on & momentary like in the G2's..??
In my 2006 I push the MFS away to turn on the high beams & pull it towards me to turn them on momentarily.
I was trying to figure out if the MFS worked in both positions, but it sounds like you only have 1 position.
Old 20 Apr 2016, 05:22 pm
On my Gen 1, when the headlights are on, you pull the left stalk half way towards you for momentary high beam and all the way towards you till they click for the high beams to stay on.
The headlamp relay is located in the interior fuse box at the bottom left side.
Got the picture from the Internet. Sorry if that offends anyone.
LionPT likes this.
Old 20 Apr 2016, 05:41 pm
Thanks, I located the relay when I was testing for power at the fuse block and checking fuses.
What's more likely, the relay goes bad or both high beams fail at the same time?
And if the high beam bulbs do fail, would that keep the high beam dash indicator from coming on?
Old 21 Apr 2016, 08:04 am
The first thing that comes to mind is the MFS because they were a problem, especially with the cars that had fog lights.
Old 24 Apr 2016, 02:22 pm
Because Trump
Old 24 Apr 2016, 03:09 pm
Thanks for the explanation and next steps to take. Will check and report back.
Old 23 Jul 2016, 10:37 am
Quick update - haven't had a chance to address the high beam issue, but then just yesterday my foglights stopped working as well (bulbs don't light and no indicator on dash).
Is it finally time to install a new MFS, or has anyone had success in repairing it more than once?
Thanks.
High beam lights raconi General PT Cruiser Discussions 4 23 Aug 2015 01:52 am
High Beam on 2001 LE Jassy General PT Cruiser Discussions 1 06 Jul 2013 12:32 pm
Stuck on high beams Agnav General PT Cruiser Discussions 2 08 Jun 2011 08:02 am
High Beams Stopper Working reh8388 General PT Cruiser Discussions 3 25 Aug 2010 07:30 am
Low Beams and High Beams jingks Exterior & Interior Styling 3 24 Jan 2008 03:16 pm
