Tail lights don't flash when opening doors remotely
Old 24 Apr 2016, 09:20 am
Question Tail lights don't flash when opening doors remotely
Hello all! I have 2001 PT Cruiser.
My tail lights don't blink any more when I use remote to unlock. I can hear the thump that the doors are unlocking, but lights don't blink. I don't know until i get close to it to see if doors are unlocked. They stopped working maybe about a month ago. Trying to find out if it could be a fuse or if it would need to be reprogrammed somehow.
I have another 2001 PT Cruiser and that one works fine.
Old 24 Apr 2016, 11:43 am
Default Re: Tail lights don't flash when opening doors remotely
Does the horn chirp when using the remote to unlock? That probably goes along with the lights that blink and on page #17 of the owners manual it tells you how to stop/start the horn chirp.
Old 24 Apr 2016, 12:37 pm
yes, the horn chirps when you lock it, not when you unlock it.
Old 24 Apr 2016, 12:46 pm
OK, dumb question, did you look at both taillights. Maybe the one your looking at is burnt out? Just guessing.
Old 24 Apr 2016, 12:50 pm
Found this: Follow the instructions for the NON-EVIC equipped cars.
To Turn Off "flash Lights With Lock; Panic Alarm - Chrysler PT Cruiser Owner's Manual [Page 25]
Read all the way to the end of that paragraph where it says how to turn them back on.
Old 24 Apr 2016, 12:56 pm
this is for lock....not unlock.
yes, bulbs and lights are working ok
Old 24 Apr 2016, 01:09 pm
But at the end it says: The "Flash Lights on Lock/Unlock" features can be reactivated by repeating this procedure.
So if yours might be turned off, try the procedure to see if it re-activates them.
Old 24 Apr 2016, 01:13 pm
huh, i guess it's worth a try. does that mean the programming is tied together then??
Because, they flash with the lock feature, just not with the unlock.
Old 24 Apr 2016, 01:32 pm
CREWZIN:
Tried it and nothing has changed. Still only work during the lock.....
That's confusing You might just have some sort of electrical fault that will need a good wiring diagram.
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Tail lights, dash lights, a/c panel lights not working ZZCruizer Tech & Performance Forum 12 14 Dec 2015 11:11 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
Cluster electrical problem? lights flash guages go right to left then out. sterioffs General PT Cruiser Discussions 0 21 Aug 2012 06:53 pm
Instument panel loses power, then all lights flash??? Samson Tech & Performance Forum 22 15 Oct 2011 09:59 am
