Ecu
Like Tree11Likes
Closed Thread
Old 24 Apr 2016, 11:11 pm
Default Ecu
Dumb question I'm sure. But since I have never dealt with this before, I need to be enlightened. I have an ECU coming in from a GT to install on my T.E. Does the ECU have to be installed for Chrysler to flash it? Or can it just pay them to connect the ecu to their computer for the flash?
Old 25 Apr 2016, 07:37 am
Default Re: Ecu
Yes, you need someone to change the vin in the ecu. Once the vin is changed, it will be plug and play. Some dealers will do this, and others will not. The ones that will not presumably do not know how to use their system to do it, so they will tell you that it cannot be done. Any mechanic shop with a more sophisticated scanner can do it too, if they know how.
Yes, the ecu needs to be installed for them to flash it. One other forum member reported that he simply used his old ecu to drive to the dealer and he swapped out the computer in the parking lot. At that point the tech came out, connected their scanner device to the OBD2 port, flashed his vin, and he was able to start and drive the car home.
You can also send it to Syked ECU Tuning and for $40 plus shipping both ways, he can do it for you too.
Old 25 Apr 2016, 01:56 pm
Default Re: Ecu
Dumb question--- whats does T.E. stand for?
To old to know...
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 25 Apr 2016, 02:49 pm
Default Re: Ecu
I'm going to guess Touring Edition.
chuzz likes this.
2016 Kia Soul Plus Black
Old 25 Apr 2016, 03:46 pm
Default Re: Ecu
Touring Edition would be my guess too. I'm not THAT old yet. I'll be 60 in August.
Old 26 Apr 2016, 12:10 am
Default Re: Ecu
T.e = Touring Edition
Old 26 Apr 2016, 12:20 am
Default Re: Ecu
Next dumb question.. Are GT's Turbos?
Are there GTs that are Touring Editions?
Opps, that two question..
73 Charger SE
01 Sebring flip
Old 26 Apr 2016, 06:28 am
Default Re: Ecu
Well, my GT is a Turbo, Joe, but it's not a TE. I don't know how they came up with so many different trim packages for one vehicle. Or why, for that matter.
Old 26 Apr 2016, 06:44 am
Default Re: Ecu
Reason for dumb questions is : Is Cubx trying to use a Turbo ECM in a non Turbo
Turbos have special ECMs I believe.
73 Charger SE
01 Sebring flip
Old 26 Apr 2016, 07:09 am
Handy_Cruiser's Avatar
Default Re: Ecu
All GT's are turbos. For several years (mostly 2004 thru 2008) both Limited Editions and Touring Editions had an optional turbo engine. These were unofficially called "Turbo Lites". The engines of the Turbo Lites are almost identical (with year to year variations) to the GT. The difference is that the ECM in the Turbo Lite is tuned to run on 87 Octane fuel. While the GT ECM is tuned to run on premium fuel. Though the reported horsepower ratings vary from year to year, the Turbo Lite is has around 180 hp. And the GT is around 220 hp. As you can see, just the tuning of the ECM makes a substantial difference.
Beyond needing to flash the correct VIN number, there are potential issues with using a GT ECM in a Turbo Lite. These may include the differences in the automatic transmission shifters, shifter indicator in the instrument cluster, and ABS. I've been prepping for this one myself since I've been looking at several convertible Turbo Lites as possible future projects. And I already have everything needed including the GT ECM, Autoshifter, GT instrument cluster and associated wiring harnesses. My plan is to run a custom DiabloSport tune on top of this, But to date, I don't know of anyone that just flashed a Turbo Lite VIN onto a GT ECU and then installed it worry-free without having to make other modifications.
An easy and better way to upgrade the ECM in a Turbo Lite is likely going to be to get a performance-tuned ECM for the Turbo Lite. For the 1st Gen 2004/2005 Turbo Lite there are Stage 1 ECM'S that will work with them and Sykes ECM Tuning also offers some. Additionally, Sykes has a handheld tuner that is reported to load a custom performance tune onto the original ECM in a Turbo Lite. The DiabloSport and other popular handheld tuners offer performance tuning for the PT GT but not the original ECM in the Turbo Lite. A GT, Stage 1 or custom ECM is needed for that. I'm not sure what if anything is available for the later 2nd Gen 2006 and up Turbo Lites.
JoeX and myckee like this.
Closed Thread
