Tail light and brake light not working
  • 1 Post By wb2kki
Old 25 Apr 2016, 04:29 am
Default Tail light and brake light not working
Here I have a 03 base PT cruiser which has been sitting for over a year.
After jumping start, I found the tail light and brake light (backing light as well, maybe, tested alone, not so sure) not working. License plate light and turning lights on the back are OK (emergency flash also fine).
Checked the shop manual, not listed in the troubleshooting list.
Anyone has some ideas about where to start the diagnose? Fuse or loosing wiring?
Old 25 Apr 2016, 06:41 am
Default Re: Tail light and brake light not working
Check the bulb first, then the socket for corrosion and then for a broken ground wire on that side.
Old 26 Apr 2016, 07:57 am
The sockets tend to burn and loose connection so yes all the above with special attention to the sockets.
It's a socket into a socket so you can replace the bulb / socket assem if you want to.
Mike
chuzz likes this.
07 PT Cruiser No Brake Light and Tail Lights SDU215 General PT Cruiser Discussions 2 22 Apr 2015 07:59 am
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
Third Brake Light and Dome Light not working metalcruiser General PT Cruiser Discussions 5 27 Feb 2012 04:03 pm
tail light broken, but brake light works dirtydmix General PT Cruiser Discussions 8 09 Mar 2011 09:59 pm
