Battery Cable issue? Starting problem with only single click sound
Old 26 Apr 2016, 03:50 pm
Default Battery Cable issue? Starting problem with only single click sound
I just want to re-post the issue.
Some times my car can not start successfully.
After I turn the key, there is only a single 'click' sound, but nothing happens, but if I hold the key in the 'on' position, the car will start.
I search the 'single click' problem in the forum, and find others also have similar issue, and someone suggest it is a wire problem, and it is due to the high resistance of the wire.
It is consistent with the my symptom. The problem only occur when it is hot and the resistance increase with temperature.
If it is the wire, do I need to replace the whole set of wires,
or just replace the positive one(red), which is connected to starter.
The OEM set is about $70, kind of expensive.
Thank you
Old 26 Apr 2016, 04:16 pm
Default Re: Battery Cable issue? Starting problem with only single click sound
Try cleaning the connections on both ends of the positive wire and see if that helps. Take it off the battery and give the clamp and post a good cleaning with a wire brush.
Old 27 Apr 2016, 08:35 am
the end of wires and the battery terminal are shining.
Old 27 Apr 2016, 09:12 am
I would suggest having a battery load test done with the battery in the PT Cruiser.
Is your engine light on?
If there are two wires on the positive battery cable next to the positive battery post check and make sure they both have good contacts.
Old 27 Apr 2016, 04:33 pm
rcktpwrd's Avatar
just because the terminals are clean and shiny doesn't mean that the wires are still good... I replaced the cable set on mine a year or so ago because the wires were corroded inside the insulation. I think it's worth it and easier to replace the entire harness that to try and replace parts of it. I got it off eBay for about 50 bucks I think.
Also like posted above the battery might be on it's way out.
Joel
www.rcktpwrd.com
Old 27 Apr 2016, 04:45 pm
Did you actually scrape the battery terminal and the thing that slides over it? Use a battery terminal brush, about $4 at any auto parts store. I just had this problem, connections looked fine but on occasion car would not turn until I tapped the terminal. Scraped it and problem hasn't returned. Anyway... If it is not the connection and it's not the battery, it is probably the cable. I'd go OEM for a part like this but it's up to you.
Old 27 Apr 2016, 06:43 pm
thanks all.
I think I will measure the resistance of the wires, then decide if it is needed to replace it.
Old 27 Apr 2016, 07:28 pm
thanks all.
I would suggest you do the battery load test before making a decision on the replacement of the battery cables.
Old 28 Apr 2016, 08:57 am
Can I do this in auto store like autozone?
Old 28 Apr 2016, 08:59 pm
I know Sears and Pep Boys will do it for free in my area so just call Autozone in your location and verify. Make sure they match the amperage on the battery when they hook up the battery load tester. Some of the employees don't want to bother and one told me they were told to just set it at 400 for 4 cylinder so make it it matches. I had them change it to 525 on my battery.
Battery cable connection help cataze Tech & Performance Forum 7 06 Jun 2014 06:55 pm
Battery cable problems. Ph0t0bug General PT Cruiser Discussions 0 09 Jan 2014 11:45 pm
Will not start click click driver window goes down Fe2orr General PT Cruiser Discussions 5 19 Feb 2013 05:12 pm
Battery Cable Assy - did I get taken? ZoomZoom71 Tech & Performance Forum 6 23 Jun 2010 08:18 pm
Battery Cable Confusion captainkrm Tech & Performance Forum 6 05 Mar 2010 10:55 pm
