HELP!! The bushings on the shifter broke
Like Tree3Likes
Old 28 Apr 2016, 05:39 pm
Default HELP!! The bushings on the shifter broke
I replaced the ones on the transmission years ago and carefully put the shifter bushings in a safe place until needed Well I need and I can't find them I tried to call Booger Bushings and they are in Houston and with all the weather I don't think they are working according to the message on the phone. Is there a quic fix or another source for these. Aside from a motorcycle the PT is my wife and I's only car and we need to get this fixed. DESPERATE! Thanks
Old 28 Apr 2016, 06:02 pm
Default Re: HELP!! The bushings on the shifter broke
You MIGHT find bushings at your local autozone, advance or o'reilly. I don't know but I'd at least call them. Maybe someone here has the doorman bushing number you need.
Old 28 Apr 2016, 07:01 pm
I tried all Autozone and they didn't have any I'll try O'Riley. Amazon May have them according to the comments. I did a quick fix with fuel hose, washer and a medium c-clip. Sloppy but stays on until I get the correct parts. I was surprised it works as it was so easy to MacGuyver together. Good thing it went out in April instead of July. I live in Phoenix Metro!
Old 28 Apr 2016, 07:06 pm
This MAY work if I can get confirmation. Very little on the O'Riley web page
Old 28 Apr 2016, 07:20 pm
I was in a similar emergency situation to get shifter bushings and they had a kit available at NAPA. They were pretty much like the stock bushings.
That's the kit in the above post.
Arizcruiser likes this.
Old 28 Apr 2016, 07:26 pm
Those will work on the shift lever correct?
Old 28 Apr 2016, 08:01 pm
jeff at booger bushings lists kits on ebay and i actually just bought a set of prothanes off of amazon. pretty sure you can get next day shipping on ebay or amazon
Old 28 Apr 2016, 08:47 pm
I'll take a look thanks
Old 29 Apr 2016, 09:33 am
think I got mine at NAPA
Old 29 Apr 2016, 10:35 am
i used these. $12 in the "HELP!" section at autozone. the isle with doorhandles and other "dorman HELP!" products.
i meant to add that the kid at the counter won't know these are there, you should physically check yourself in the "help" isle
Manual shifter bushings? jrunner Tech & Performance Forum 8 07 Aug 2015 12:03 am
PT shifter bushings replacement discovering06 Tech & Performance Forum 16 11 May 2015 05:03 am
Shifter linkage bushings mikelikestobike Tech & Performance Forum 3 15 Feb 2012 08:54 pm
Broke PT Turbo and Broke daughter ptturbodad Turbo Performance 10 22 Sep 2011 10:15 am
B&M Short Throw Shifter & Booger Bushings proxeyed Classifieds: For Sale/Trade 8 08 Mar 2011 10:54 pm
