Battery change
Old 30 Apr 2016, 09:14 am
Default Battery change
Changed out my battery, then all hell broke out. Now brake light and rear turn light come on when breaking, right front head light doesn't work but the bulb is good. Air bag and brake indicator on the dash are lit up and the wipers are on or off, no more delay. The rear wiper come on with no delay in between. I've done this, remove battery and connect position and negative together to drain the juice out of the system but no luck. Need so help.
Old 30 Apr 2016, 09:42 am
Default Re: Battery change
You've had three other threads on problems about the same as your having now. The TIPM (Totally Integrated Power Module) was one of the answers given that helped cure other owners problems with the same symptoms. Did you ever try replacing that?
Here's an older thread that might help.
Integrated Power Module (TIPM) 2006 PT Touring Edition 4dr, 2.4L
By the way, not everybody reads olde threads like I do so it would help to tell every one again that's in a 2006 with about 100,000 miles.
Old 30 Apr 2016, 11:02 am
How was the previous electrical problems taken care of or are they still there?
Old 30 Apr 2016, 01:27 pm
Just finished up by removing battery and cleaning all grounds in the engine bay. Found a ground broke on the passenger side wheel well going to the front strut. Check all fuses, don't known where to go from here.
Not giving up, need more help.
Old 30 Apr 2016, 02:11 pm
Good luck! If you are not interest in answering the previous posts I hope you still get some help.
Old 30 Apr 2016, 03:03 pm
The post from cruzzin was not pt, did help a little.
Old 30 Apr 2016, 03:35 pm
This is the post that was not answered.
Old 30 Apr 2016, 06:38 pm
WHAT, not a PT? It's all about a 2006 PT Cruiser just like yours!
The little voice in my head said change your battery Dino General PT Cruiser Discussions 27 29 Jan 2012 08:06 pm
Vid on how to change the battery WolfmanG General PT Cruiser Discussions 1 30 May 2011 10:08 pm
trying to change battery ??help !! bobs turbo pt General PT Cruiser Discussions 4 20 Feb 2011 05:57 pm
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
How difficult is it to change battery cables? sawdust123 General Turbo Discussions 0 20 Aug 2007 12:57 am
