P03040 and p1391
Old 01 May 2016, 01:17 pm
Default P03040 and p1391
Help please , p03040 is no cam reference at pcm and p1391 is interm loss of cmp or ckp, I was told it was my camshaft position sensor so I replaced it , but still the same thing. It starts and runs until put in drive and once in drive it chugs and dies!! Any ideas ???
Old 01 May 2016, 01:45 pm
Default Re: P03040 and p1391
I would suggest checking the wiring going to your camshaft and crankshaft sensor.
Check to make sure your crankshaft sensor is working properly.
What year is your PT Cruiser?
I would suggest you introduce yourself to the forum and post about your PT Cruiser.
Old 01 May 2016, 04:17 pm
It's 2001
Old 01 May 2016, 04:31 pm
Make sure the clip holding up the crankshaft wire harness did not break allowing the wire harness to run on the half shaft shorting out wires. This has been happening to other members on the 2001 PT Cruisers.
P1391 and P0340 Deepstar Tech & Performance Forum 8 11 Jan 2013 05:33 pm
codes p1391, p0340 soyomb Tech & Performance Forum 6 29 Oct 2012 08:45 pm
2001 PT has P1391 code sportsguy585 Tech & Performance Forum 8 11 Jan 2011 12:28 pm
P0340 & P1391 Rippsnorter Tech & Performance Forum 3 10 Jun 2010 11:37 pm
Error code P1391 rhsposta Tech & Performance Forum 8 13 Apr 2010 05:10 pm
