2006 pt cruiser horn relay
Like Tree2Likes
  • 1 Post By chuzz
  • 1 Post By Fk5
Old 04 May 2016, 08:35 pm
Default 2006 pt cruiser horn relay
I just got a 2006 pt cruiser and the horns not working.i cant findwhere the relay for it is. Can anyone let me know where its location is please?
Old 04 May 2016, 10:12 pm
SvenCruiser's Avatar
Default Re: 2006 pt cruiser horn relay
How about checking the owners manual?
If you don't have it you can download it here https://www.manualowl.com/a/Chrysler...er/Manual/1673
PT CRUISER 2.2 CRD Turbodiesel
Old 05 May 2016, 05:48 am
I don't think the GenII PT's have a horn relay, but I could be wrong. I usually am, according to my wife.
LionPT likes this.
Old 05 May 2016, 07:21 am
Fk5 Fk5 is offline
Yep, Lion informed me of this a couple of days ago when I suggested (demanded?) using it to check if the ASD relay had a problem. I didn't pipe in because I have a G1 and figured I would let somebody that knows first hand respond.
LionPT likes this.
2003 GT 5 speed
162,000 miles
Old 05 May 2016, 08:13 am
LionPT's Avatar
Like others have said, there is no horn relay/fuse in the G2's 2006-2010.
But here are some things to check...
  • Does the horn beep when setting the alarm..?? Does it go off when you press the panic button..??
  • If it does, push the horn above & below the Chrysler emblem on the steering wheel...push down really hard...just don't tap it.
  • If not, you need to pull the passenger side fender well to check wires.
Tags
horn, relay
2006 PT Cruiser Fuel Pump Relay Sweaty_AZ Tech & Performance Forum 2 09 Jun 2014 08:11 pm
horn relay daytonalen Canada PT Forum 0 25 Aug 2013 09:37 am
2006 PT Cruiser - How to disconnect the horn so can use the car! uley1929 General PT Cruiser Discussions 13 18 Mar 2013 02:09 am
Horn Problems on 2006 PT Cruiser jkranites General PT Cruiser Discussions 5 21 Jun 2012 10:55 am
Location of 2009 Horn Relay James001 Tech & Performance Forum 4 20 Apr 2011 02:30 pm
