PT missing
Old 07 May 2016, 12:01 pm
Default PT missing
2005 PT it starts and runs but is missing badly have put new crank cam sensors plugs check the compression still missing anyone have any suggestions
Old 07 May 2016, 12:13 pm
Default Re: PT missing
Welcome to the forum.
We need more information for a complete diagnosis. How many miles, last time the timing belt was replaced, everything that was done to try and fix this problem.
If its missing badly the engine light should be on. What engine trouble codes are you getting? Do you have your own OBDII Scan Tool?
Old 07 May 2016, 12:41 pm
Read this
PT problems read this FIRST
Old 07 May 2016, 05:49 pm
Gee, let's see. Plugs, wires, clogged air filter, dirty injectors, filthy throttle body, etc., ect. WE NEED MORE INFORMATION!
Old 07 May 2016, 08:34 pm
Fk5 Fk5 is offline
Turbo or not a turbo? Which manifold? Is it just missing or are you getting a code? If you're getting a code, which code? Etc. etc.
2003 GT 5 speed
162,000 miles
Old 08 May 2016, 06:34 am
SvenCruiser's Avatar
Ha,I thought you meant it was stolen
PT CRUISER 2.2 CRD Turbodiesel
Old 08 May 2016, 07:13 am
So did I.
Missing at idle VegasPTGT Tech & Performance Forum 3 25 Oct 2013 06:49 pm
What am I missing? Jacob Tech & Performance Forum 0 04 Aug 2011 09:12 am
The missing key careyk General PT Cruiser Discussions 3 09 Apr 2009 02:33 pm
MISSING AGAIN/HELP kromans Turbo Performance 8 24 Jan 2005 11:59 am
missing horn cruisergt General Turbo Discussions 10 23 May 2003 12:01 am
