Thursday the 04 Limited Turbo 2.4L threw code p2305 and I'm really stumped. I have replaced plugs, wires, ignition coil and still runs rough(vibration at idle and almost zero power when pressing the pedal) and still has the same code. Today I tested the wires from the pcm(fairly new pcm) that go to the coil with a light probe. The wire that corresponds with cylinders 1 & 4 was working well with a blinking light while the engine was running. The wire that corresponds with cylinders 2 & 3 did not blink while running! Checked for a short on that wire to the pcm and id not find a short!!! Really hoping this is not my pcm seeing that i just dumped $800 on a new one just over a year ago. Any help would be greatly appreciated!
Any chance that there could be a shorted wire to the Crank Sensor or Cam Sensor without throwing a code? |
![]() Quote:
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
P2305 - Ignition Coil No. 2 Secondary Circuit Insufficient Ionization Conditions:
If PCM detects that the secondary ignition burn time is incorrect or not present an error is detected. Possible Causes: 1. Intermittent condition Cylinder No. 2 spark plug or wire is damaged or it has failed 2. Ignition Coil No. 2 is damaged or it has failed 3. Ignition coil control circuit is open or shorted to ground 4. ASD relay output circuit problems 5. PCM has failed One of our members indicated after replacing the crankshaft sensor that it fixed the P2305 code. 2005 2.4 Turbo stalls sets code P2305
If at First You Don't Succeed - Try, Try Again |
Thanks for the help but after further checks I have figured out that it is the computer. Good news is that I found out it is still under warranty! If this fixed it I will make another post to confirm!
Thread Tools | |
Display Modes | |
Code P2305 (secondary coil) after timing belt changed | StuPTendous | General Turbo Discussions | 2 | 06 Mar 2015 01:08 pm |
2005 2.4 Turbo stalls sets code P2305 | ratnin57 | Tech & Performance Forum | 4 | 29 Aug 2009 09:51 am |
P2302, P2305 & P0300 | sjzdx | Tech & Performance Forum | 5 | 26 Aug 2009 08:43 pm |
