pt won't accept gas
Like Tree8Likes
Old 12 May 2016, 01:37 pm
Default pt won't accept gas
My 2001 won't take gas, it just shuts the pump off. Any ideas how to fix? Thanks
Old 12 May 2016, 02:28 pm
cruserdad1976's Avatar
Default Re: pt won't accept gas
well sounds like a blocked filler tube?? you might have to drop the tank and check the hose and make sure nothing is blocking the fuel path
Old 12 May 2016, 02:39 pm
Fk5 Fk5 is offline
It depends on how severe it is. Vent problems will often cause the pump to stop prematurely, but if it won't take anything, the fill tube is certainly prime suspect.
2003 GT 5 speed
162,000 miles
Old 12 May 2016, 03:56 pm
id even say it might be kinked but if it has been taking fuel and unless it was in a accident cant see how
ptprice likes this.
Old 12 May 2016, 04:48 pm
Did you make some one mad lately? Did some one shove something down the gas filler neck to get even?
I'd check the tube as far as I could see using a flash light and screw driver to hold the little door open.
ptprice likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 13 May 2016, 08:25 am
It will take some. It takes about 5 min to put in a gallon. Is there a vent of some kind in the tank or is it in the filler? Thanks
Old 13 May 2016, 08:31 am
Does it have a locking gas cap?
Old 13 May 2016, 10:09 am
I think there is a vent I have heard that some PTs have this problem but the big question is
DID IT JUST START ding this or has it been this way all along??
Old 13 May 2016, 11:44 am
ptprice's Avatar
Short of removing the filler tube for inspection or replacing the vent tube, both expensive and time consuming, keep in mind visual inspection can only tell you so much. I suggest before doing anything expensive, removing the gas cap, and immediately putting your nose as close to the opening and sniff. If you don't get a full blown nose full of gas fumes but just a smidgen of scent, there truly might be a partial blockage in the fuel filler tube. Vandalism or accidental. If so, a long flexible pick up devise with a claw on the end might grasp the offending blockage and allow extraction. I'd at least try that before the big bucks solutions.
Same thing happened to me 55 years ago. Lost the gas cap, put a rag in the filler tube, took the rag out, put a new cap on, wouldn't take on fuel. A segment of the rag had deteriorated and broken off, blocking the filler tube.
Of course that was also back in my earlier years when my next gallon of gas might come from fuel siphoned from a friends car. A low bucks solution to lack of cash! I could identify any brand of gas by the flavor.!
Happy Ptin', ptprice
rockandroller likes this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 13 May 2016, 11:49 am
its not really that hard to drop the tank
kind of matters how full the tank is or how EMPTY
just unbolt it and hold on
check the hoses the important thing then is to make sure you get it back on with out any kinked hoses
cd player won't accept disc racerev Sound and Security Forum 1 07 Feb 2016 12:14 am
