No crank No start
Old 14 May 2016, 01:52 pm
Default No crank No start
Ok so I am new to this forum and just looking to get a little insight. I have a 2001 PT Cruiser Non Turbo Automatic. I just finished rewiring my main harness due to brittle wires and constant fuses being blown. Well I got everything wired correctly and was starting fine. But I noticed my ect sensor pigtail was also bad. So as I was in the process of rewiring I grounded out one of the wires accidentally. Pretty stupid o me because I usually disconnect the battery before I do any electrical work. Anywho after grounding out that wire I heard a faint zip noise. Now I have no crank/no start situation. I'm hoping I didn't short out the pcm. All fuses and relays are good. But I'm getting no fuel or spark, that's why I'm leaning to the pcm.
Old 14 May 2016, 03:07 pm
Default Re: No crank No start
Welcome to the forum
I would suggest you introduce yourself to the forum.
I would suggest checking your ASD fuse under the hood.
I would suggest you check to see if you still have voltage on C2 connector pin 29 at the PCM. Post what you find.
03 No crank, No start sassylisey General PT Cruiser Discussions 11 11 Sep 2014 10:52 pm
Crank no start on 02 PT Cbdani2 Tech & Performance Forum 10 26 Aug 2014 03:31 pm
CRANK BUT NO START clifford General PT Cruiser Discussions 3 27 May 2014 11:15 pm
03 crank no start. spike General PT Cruiser Discussions 3 19 Jan 2012 08:44 am
