Ignition actuator pin
Old 17 May 2016, 10:10 am
Default Ignition actuator pin
I was replacing my ingition switch on my 2006 pt cruiser and noticed that my actuator pin was broken. I cannot find the assembly without purchasing the entire column lock housing.
Any recommendations that do not involve buying the entire column?
Old 18 May 2016, 09:42 am
Default Re: Ignition actuator pin
Broke mine same way the only thing the pin does is beep when the key is in and car off. I'm just living with it and it has not been a problem.
Mike
Old 18 May 2016, 11:37 am
Welcome to the forum
Old 18 May 2016, 02:12 pm
Thanks Mike. That helps alot. The 06 seems to be the hardest to get parts for.
Phil
Old 18 May 2016, 03:28 pm
Welcome to the forum.
06 ignition sw actuator pin wb2kki General PT Cruiser Discussions 9 27 Oct 2014 01:13 pm
Ignition Switch/Actuator TaupeCruiser General PT Cruiser Discussions 2 30 Dec 2013 12:30 pm
actuator pin/ ignition barrel colingreen General PT Cruiser Discussions 1 27 Dec 2012 12:25 am
Ignition Actuator dgarm Tech & Performance Forum 14 19 Jun 2011 11:50 am
Ignition actuator replacement tbirdt94 General PT Cruiser Discussions 2 20 Feb 2011 03:12 pm
