Does Anyone Know Which Wire
Like Tree6Likes
  • 3 Post By sanatanadharma
  • 2 Post By sanatanadharma
  • 1 Post By chuzz
Old 18 May 2016, 11:32 am
Default Does Anyone Know Which Wire
Okay Peeps, I've figured out there's a pinched wire in the steering column that determines whether or not my radio/clock display lights up. When it's dark, I can tilt the wheel just a tad in either direction and it lights up. For a while. Then it goes out and I have to tilt it again. I've got no problem clipping wires and soldering them back together, but I'd like to know if anyone has a schematic that shows which color wire might be the one I need to splice. I don't have a schematic and hate guessing. I'd like to just be able to cut, splice, solder, shrink wrap and be done. Thanks for any help. On a side note, I checked the mileage after a 221 mile trip yesterday and got 25.1 mpg out of the turbo! And I had her cranked up to 95 once for about a 3/4 mile stretch. Had a tractor trailer to get around before it went back to a two lane highway!
Old 18 May 2016, 01:20 pm
SpannerHound's Avatar
Default Re: Does Anyone Know Which Wire
I could send you the wiring diagrams I have (01-04 & 07) if you're stuck
Old 18 May 2016, 01:32 pm
Because Trump
ptprice, JoeX and chuzz like this.
Old 18 May 2016, 02:16 pm
LionPT's Avatar
There are a few posts on site that say adding an extra ground wire to the column will fix this issue also (if the wire isn't pinched).
Old 18 May 2016, 03:52 pm
Originally Posted by sanatanadharma View Post
AT the ignition switch connector C1, look for the black/white (14 gauge) wire in pin #7.
This wire distributes run/acc31 circuit power to the fuse block fuses #14 & 15.
#14 protects the ignition switched power to the radio; also the moon roof, map lights and overhead console.
#15 protects the wipers, front and rear.
Therefore all of these functions will go off with the radio if the run/acc31 circuit wire is the problem (wipers would be easy to check).
If the power feed circuit to the ignition switch were the issue, at least six other fuses and the associated circuits would be failing
I appreciate the info, man. BUT everything still works except the display on the radio. Moon roof, map light and overhead console are not affected at all. It's very strange. Wipers are not affected either. It's JUST the radio display. I'm going to go out and tinker with it in a few minutes.
Old 19 May 2016, 09:56 am
Because Trump
ptprice and LionPT like this.
Old 19 May 2016, 10:54 am
Thanks, Sanatanadharma. I found one wire that seemed to "sag" somewhat near the pivot point of the tilt and zip tied it up. So far, so good. It's damn near just too hot and humid to fool with already today if it acts up again. I MAY just leave it alone until it gets to tilting the wheel stops working all together!
Old 23 May 2016, 08:42 pm
rcktpwrd's Avatar
My car had the intermittent radio display, along with the key in ignition chime not working. I had checked over all the wires running up the column and everything was just fine, no amount of wiggling, jiggling, pushing or pulling on them made any difference. Playing with the key in the ignition made no difference either.
Adding the extra ground wire, like posted above, cured both issues. I did this several years ago and it's been perfect since.
Joel
www.rcktpwrd.com
Old 23 May 2016, 08:48 pm
Thanks for the input, Joel. I found one wire that was close to the pivot point on the wheel and zip tied it up. No problems since. If it comes back, I'll run that additional ground like you did.
rcktpwrd likes this.
What does this wire in wheel well do? Nick529 Tech & Performance Forum 7 09 Jan 2015 07:46 am
What to do with this wire? blackSCpt Sound and Security Forum 3 22 Sep 2013 10:56 am
P0750 and a little red wire, and a blue wire? gwairbrush General PT Cruiser Discussions 1 20 Jun 2013 06:39 am
wire help? careyk General PT Cruiser Discussions 7 01 Nov 2011 09:14 am
power wire bhunt41 Sound and Security Forum 16 21 Dec 2010 06:32 pm
