Cylinder head warped how much is to much to have resurfaced
Like Tree2Likes
  • 1 Post By NitroPT
  • 1 Post By ptcruisersteve
Old 19 May 2016, 02:35 pm
Default Cylinder head warped how much is to much to have resurfaced
How much warp can be milled off before head is not use able after head is cut and bolted back on, the camshafts rock up and down with caps on i can't turn them by hand
Old 19 May 2016, 03:15 pm
Default Re: Cylinder head warped how much is to much to have resurfaced
IMO if you can not freely rotate the camshaft (s) shafts with the cam caps secured even hand tight on or off the short block.... dump the head.
Other wise the rule of thump for myself and Mike (Thumper Performance) is a maximum .30 from oem (never been surface). Keep in mind this will also effectively raise the CR by aprox.1/2 point. However the head or engine machine shop doing the surfacing must determine what they will surface a head at in which they determine to be their safe limits and you should take their advise.
VsandFords likes this.
Old 19 May 2016, 04:27 pm
Ok it was at least .60mm so off to the search for a new head
Old 20 May 2016, 10:01 am
I would check the the block as well before investing. Check the top of the block for flatness and make sure the the cylinder walls didn't bow out.
Mike
Old 20 May 2016, 03:07 pm
Mike
It is a nice thought but really does not apply so much to the Chrysler 2.4 cast iron block. The castings are thick and the water jackets plentifully. It would be nearly impossible to change the deck condition from factory specification on these engines. They are pretty bullet prof in that area.
Old 20 May 2016, 04:50 pm
Mike
I would have to agree with Lynn(AKA) NitroPT. On the block. If you have any cam rock. Get another head.
Old 20 May 2016, 09:05 pm
.60 mm = 0.023622 inches
NitroPT likes this.
Advice: Warped Head/gasket or Cracked Block? Daddie0 Tech & Performance Forum 19 18 May 2015 05:21 pm
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
warped head?? mdskinner731 Classifieds: Want To Buy 4 08 Aug 2011 08:47 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
HEAD , Hd Gskt, Valves warped among other things outfit Tech & Performance Forum 2 15 Feb 2010 12:46 pm
