02 to 03 heated mirror swap question
Old 20 May 2016, 07:53 pm
Default 02 to 03 heated mirror swap question
I just purchased a 03 PT cruiser to replace my 02 PT cruiser and have a question about a swap on the heated mirrors. I found out they dropped the heated mirror option on the 03's and up on some models and on mine they did. Some guys have purchased heated mirrors from older models, plugged them in, and they worked fine. Before looking, I ordered a set of 02 heated mirrors, went to install them, and the wiring is there in the door harness, but Chrysler left out the prongs to put the fuse in the factory fuse block. So plugged the heated mirrors into the plug and within minutes the battery was dead and had to put the battery charger on to get the car to start. Put the non heated mirrors on and the car works fine. Question one is there an easy way to get the heated mirrors to work with the factory wiring in place, but no power or fuse in the fuse block? And question two is why would it drain the battery so quick if there is no fusible power to the heated mirror option? Just bouncing this around to see what I can do or just settle for the non heated mirrors.
Old 20 May 2016, 08:14 pm
LionPT's Avatar
Default Re: 02 to 03 heated mirror swap question
AFAIK, the heated mirrors only work when the rear defroster/defogger is on.
WTB 2001 PT Cruiser power/heated side view mirror & switch body connectors herbie53 Classifieds: Want To Buy 2 17 Nov 2012 03:42 pm
Heated mirrors question. JoeCruiser Exterior Accessories Forum 7 29 Oct 2012 12:10 pm
heated wing mirror/rear window demister cannycope General PT Cruiser Discussions 3 09 Feb 2011 12:04 am
Heated mirror problem chuckd1991 General PT Cruiser Discussions 2 03 Oct 2010 01:58 pm
WTB: Drivers side mirror glass, heated, '02 vk Classifieds: Want To Buy 4 16 Mar 2006 01:47 pm
