wiper fluid reservoir screw size
Old 21 May 2016, 08:31 pm
Default wiper fluid reservoir screw size
Tried to install a cabin air filter, but found out need a driver to remove the screws that secures the reservoir
Just wonder if anyone know what size it is, 10mm?
Thanks
Old 22 May 2016, 06:42 am
Default Re: wiper fluid reservoir screw size
Yes, they look to be about 10mm but should be easy enough to switch to a different size if it's not, unless you only have one socket. ...and according to this video, you don't remove the 3 nuts securing the washer reservoir, you only have to loosen them.
P.S. Did you ever get your tail lights to work? It would be nice if you let us know if any of the answers given to your question helped you out. You never replied to your question back in April.
Hissing near brake fluid reservoir ptkwt General PT Cruiser Discussions 5 09 Jul 2014 04:09 pm
Picture of clutch fluid reservoir cap ? rasec8711 General PT Cruiser Discussions 19 30 Dec 2013 09:35 am
2006 ignition shroud screw size? Samson Tech & Performance Forum 1 22 Apr 2012 10:37 pm
Need Dash Tweeters Measured Screw to Screw- MoparHemiPower Sound and Security Forum 3 13 Sep 2011 06:41 pm
Rear wiper fluid bella_blu General PT Cruiser Discussions 7 04 Mar 2011 09:18 pm
